Front Door Paint Advice - Painting - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 08:44 PM   #1
Front door paint advice
Should I paint my sidelights as well as the front door?
lana77 is offline   Reply With Quote
Old 06-09-2011, 09:40 PM   #2
Rewards Points: 150
Do you have a pic of your house.
josall is offline   Reply With Quote
Old 06-13-2011, 05:11 PM   #3
www.doors4home.com
jason.r's Avatar
If the door and the sidelite match in design, would think that you would also like them to match in color. If you are going for a specific design technique, then it would be hard to tell without looking at it.
Jason
jason.r is offline   Reply With Quote
Old 06-17-2011, 10:50 PM   #4
exterior oil base semigloss paint probley best(side effects has high akline and mildews faster) latex semigloss does not stick as well peel like rubber band
darreng is offline   Reply With Quote
Old 06-18-2011, 03:11 AM   #5
Too Short? Cut it Again!
High acrylic content with superior UV protection in a water-based suspension would be my first choicel Semi-gloss for a door I suspect but no firm rec until you post a picture.
Rough up the current door surface and prime with a solvent based ALKYD primer. Then two coats of finish. You can use either oil based or water based finish over alkyd. I just think you are going to get better mileage from an acrylic paint film.
Old 06-18-2011, 12:38 PM   #6
Faron79's Avatar
Rewards Points: 260
Ignore the post by Darreng....
Sdsester's advice is perfect.
If the project's not already done, what final color are ya doin'?
A darker primer may be advisable.
Faron
Faron79 is offline   Reply With Quote
The Following User Says Thank You to Faron79 For This Useful Post:
Gymschu (06-18-2011)
Old 06-18-2011, 01:04 PM   #7
Excellent point. If using a deep color, have the paint store tint the primer with 40-50 percent concentration of your chosen finish color formula.
Old 06-18-2011, 01:52 PM   #8
Gymschu's Avatar
Rewards Points: 658
Maybe 20 years ago this was true, but, not anymore. I always liked oil on doors (especially metal) for its' hardness and durability. Now, the latexes have caught up and you can basically get that same, hard, durable finish as you once got with oils. Oils take too long to dry and you have to leave your door open to bugs, etc. for a long period of time. Most people I work for paint the sidelights the same color as the door.
Front porch shed roof addition GIDGEEGIRL1 Building & Construction 0 10-28-2010 12:16 AM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 06:08 PM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 11:01 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
