Old 11-29-2011, 07:28 PM   #1
freshly painted cabinets easy to scratch
I just finished painting my lower cabinets and notice it's really easy to scratch and chip. Is there a sealer I can use?
diywendy is offline   Reply With Quote
Old 11-29-2011, 08:09 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
what type of surface prep and paint did you use. some paints will stay soft and will not fully bond or harden for several weeks. more info would help us give you a better answer..
mustangmike3789 is offline   Reply With Quote
Old 11-29-2011, 08:22 PM   #3
sdsester's Avatar
Latex semi-gloss, for example, takes about 30 days to cure even though it skins over and dry to the touch quickly. You would not want to put a clear coating over it until it has cured or it might never.
sdsester is offline   Reply With Quote
Old 11-30-2011, 12:04 AM   #4
Gymschu's Avatar
Did you prime? If you painted without a quality bonding primer those puppies will scratch, chip, and peel. On my most recent job, I primed with CoverStain and topcoated with SW's Proclassic Semi-Gloss. After a month, the finish is cured to a rock hard finish......no need for a sealer.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (11-30-2011)
Old 11-30-2011, 01:29 AM   #5
what did you paint over? were the cabinets stained and cleared or painted? did you clean any of the dirt and grease off of them? did you sand?
The Following User Says Thank You to DannyT For This Useful Post:
ltd (11-30-2011)
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 07:14 PM
will virginia mills engineered floor scratch easy? elizabeth1 Flooring 1 06-05-2011 07:31 AM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 08:48 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Refacing Painted Cabinets tripdls Carpentry 4 11-04-2006 12:34 PM
