French Doors - Painting - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 05:03 PM   #1
Rewards Points: 33
French Doors
I have a set of doors, separating a living rm and dining rm. I had the doors refinished (stain/varnished) my problem is the windows in the doors 15 panes on each door, the windows on each door have become coated with some type of white film on the windows after refinishing, WHAT WOULD BE A GOOD CLEANING SOLUTION TO REMOVE THIS WHITE MILKY FILM FROM THE WINDOWS WITHOUT DAMAGING THE WOOD THAT SEPARATES THE WINDOW PANES. I'VE TRIED EVERYTHING FROM RAZOR SCRAPING TO HOME REMIDIES . WITH LITTLE SUCESS
jjchips is offline   Reply With Quote
Old 06-09-2013, 05:10 PM   #2
Rewards Points: 13,732
Are you sure the film is not between the panes of glass?
Old 06-09-2013, 05:13 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Use a flashlight and shine it at an angle.....you should be able to see if the film is between panes of glass....
My fear is that it's tempered laminated glass....who ever did the stripping used stripper that got into the glass....and melted the laminate....
If this is the case....replacing the glass might be your only option....
One thing you can do without damaging anything....use a sharp razor blade and scrape the surface of the glass....if anything is on it...it will scrape off.
ddawg16 is online now   Reply With Quote
Old 06-09-2013, 05:18 PM   #4
Rewards Points: 33
French doors
Oh yes, i've tried cleaning solutions but nothing seems to cut the milky film, not so sure that i should remove doors, and put on a work bench try to clean that way,, i would like to know how to remove each single pane but not sure which side of door would be easiest to remove the small would trim
Old 06-09-2013, 05:21 PM   #5
kwikfishron's Avatar
Rewards Points: 598
If you paid a company/contractor to refinish these doors for you then this should be their problem to resolve, not yours.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Brushjockey (06-10-2013), chrisn (06-10-2013)
French Doors are a PITA JackOfAllTrades Windows and Doors 14 12-09-2011 09:45 AM
French Doors Don't Meet In Middle tima2381 Building & Construction 11 03-07-2011 05:42 PM
Exterior french doors install? imola ghost Carpentry 3 11-16-2009 05:06 AM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 10:26 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
