Foul Odor On Closet Doors After Priming - Painting - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 11:32 PM   #1
Rewards Points: 12
Foul odor on closet doors after priming
I'm a total newbie/amateur that moved into an apartment with pretty dirty closet doors (pictured below) that hadn't been painted in 30 years. Following recommendation, I used Aqua Lock to prime the closet doors then painted over it a week later w/Benjamin Moore Regal semi-gloss. Now the closet doors give a nasty foul odor that has lingered for literally months! Other closet doors of the same material were painted over with no primer and I don't have the issue. PLEASE give me some recommendations or suggestions on how I can correct this short of replacing these doors. Thanks in advance!
Foul odor on closet doors after priming-cl.jpg   Foul odor on closet doors after priming-cl2.jpg
diybifold is offline   Reply With Quote
Old 02-18-2013, 12:23 AM   #2
747
registered
747's Avatar
Rewards Points: 534
Looks like something is going on behind those spots.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
Gymschu (02-18-2013)
Old 02-18-2013, 03:32 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
As mentioned, did you just prime over the dirt and maybe mold?
Old 02-18-2013, 11:03 AM   #4
Rewards Points: 12
Actually those pics are of closet before any painting was done
Old 02-18-2013, 11:06 AM   #5
Rewards Points: 12
I cleaned them with water and some dish washing detergent and let them dry before applying primer. From googling terms such as "bad odor after priming" and "bad smell primer" it seems others have had similar issues and are suggesting products like Zinsser shellac based primer to cover up. I'm wondering if it's the type of material the closet is made of thats doesn't like the latex primer I used. Not sure exactly what it's made of but it's kinda looks like material Ikea furniture is made of but a lot sturdier.
Old 02-18-2013, 11:54 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
Did it smell before you painted? Also you are saying closet doors- not interior of closet. Was the interior ( where the spots are) also painted?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-18-2013, 12:56 PM   #7
Rewards Points: 12
No smell before painting, just discoloration / stains from neglect. The interior which is dry wall was painted but doesn't give off an odor. Only the doors give off odor.
Old 02-18-2013, 01:12 PM   #8
Boy- that's a hard one. The prime/ paint shouldn't have activated something.
Here is an idea- pop them off and move them to another area and see if they still have an odor. I am still suspecting the interior more than the doors.
Old 02-18-2013, 01:21 PM   #9
Rewards Points: 12
Interiors of the closet were painted a week or so before the doors and any didn't give off any odors except for a fresh paint smell for a few hours after applying the paint. Its definitely the doors.
Old 02-18-2013, 01:25 PM   #10
Well, about the only suggestion left is to re do with BIN. Make sure to also do the tops , bottoms and sides. BIN can stop cat urine, so it's about the best odor killer there is. It is an alcohol (denatured) based shellac- and dries very quickly. Put it on and leave it. Not time to work it.
good luck!
Old 02-18-2013, 04:48 PM   #11
747
registered
747's Avatar
Rewards Points: 534
Oh i messed up your post. I thought walls your saying doors. Just take them off. Then to garage or outside. Litely scuff up with some sandpaper and hit with bins. Make sure you buy some denature alcohol for cleanup. Hands,brushes. This is oil based. If this doesn't work i don't know what to say.
Can I get Custom 6 Panel Doors At Odd Sizes? heyjoe91 Remodeling 5 09-14-2012 04:54 PM
french closet doors Liz W Windows and Doors 0 03-20-2012 07:40 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 02:38 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
Mirrored closet doors VVAVALE Painting 2 08-19-2006 06:34 PM
