Forgot To Prime Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 10:05 AM   #1
Unhappy
forgot to prime ceiling
Help! We scraped the popcorn off of our kitchen ceiling, filled in some holes, sanded, and then painted. The paint wasn't adhering in some spots and we realized we should have primed over the drywall first. Is it too late to prime now (over the first coat of paint)? The ceiling looks REALLY bad. What can we do to fix it?
ncnelsons is offline   Reply With Quote
Old 06-15-2009, 12:21 PM   #2
The primer won't help the paint that is already up to adhere
But if you have areas that won't take paint then paint with primer
Old 06-15-2009, 08:21 PM   #3
Rewards Points: 346
I am not sure priming would have helped much if you noticed the paint not sticking right away. It sounds like there was dust or residue on the ceiling. Did you clean it before you painted it and if so what did you use and what was your procedure?
RegeSullivan is offline   Reply With Quote
Old 06-15-2009, 08:30 PM   #4
Also, if the entire layer of popcorn was not scraped off that can be a problem. The moisture from the paint can cause the layer to peel off
What do you mean exactly by not adhering?
Old 06-18-2009, 01:29 PM   #5
Kellster
mjkpainting's Avatar
Rewards Points: 77
Let the paint completely dry
Scrape any loose chipping paint
Apply a coat of Zinnser Gardz as a primer- this product works wonders
http://www.zinsser.com/product_detail.asp?ProductID=27
Patch/Skim coat the the ceiling
Sand it
Spot prime areas that you applied heavy coumpound
Paint it
mjkpainting is offline   Reply With Quote
Tags
popcorn ceiling
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
What first ?! Ceiling or Walls? Do I need to prime? yohan Painting 6 07-26-2008 10:35 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
