Foam Rollers For Walls? - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 09:56 AM   #1
Rewards Points: 264
foam rollers for walls?
I am painting new walls in a laundry/mud room. The walls are primed, drywall work was done well. I did the ceiling with a 3/8 white dove and that went fine. I have about 38" of wainscot, then walls up to about 7' 8", so not a lot of wall. I am going with a semi gloss on the wainscot, satin on the walls. I primed the wainscot with a 6" foam roller and it worked well. Any problem with using a foam roller on the walls?
Thanks for comments/opinions!
7echo is offline   Reply With Quote
Old 01-17-2009, 10:28 AM   #2
Rewards Points: 506
The problem with using a foam on a wall, as best I can guess, is that the paint will have a tough time "flowing" out of the foam; instead you will have to squeeze. That WILL lead to inevitable roller marks. I am also guessing that a foam roller will hold less paint, making the job take longer.
Personally, I wouldn't risk $20 of paint to experiment with using an alternative to a $3 roller cover.
If you do try the foam on the wall, let us know how it turns out.
SirWired
sirwired is offline   Reply With Quote
Old 01-17-2009, 02:16 PM   #3
Rewards Points: 2,906
The ONLY time I ever use foam rollers is when I'm painting wood moldings because the foam roller puts a thinner coat of paint on. If I use a regular roller sleeve, then paint gets squeezed out of it and ends up dripping off the edge of the wood moldings.
I've seen larger foam rollers (like 7 inch foam rollers) and I'm wondering what people use them for? Walls?
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-18-2009, 09:28 PM   #4
Yeah, foam is best for very thin coats so while there isn't a "problem" with using it I think it would take longer and isn't worth it.
Mark, MN Painters Network
markpainter is offline   Reply With Quote
Old 01-19-2009, 08:17 AM   #5
Rewards Points: 264
thanks
Appreciate the comments.
I will use the 3/8 cover, don't want to make this an experiment.
Thanks again!
Old 01-19-2009, 05:49 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by 7echo
...I will use the 3/8 cover
slickshift is offline   Reply With Quote
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 10:07 PM
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 03:07 AM
Exterior Foam Insulation Help??? teachtech Building & Construction 3 11-29-2008 10:19 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
