-   -   foam rollers for walls? (http://www.diychatroom.com/f4/foam-rollers-walls-36134/)
7echo 01-17-2009 10:56 AM
I am painting new walls in a laundry/mud room. The walls are primed, drywall work was done well. I did the ceiling with a 3/8 white dove and that went fine. I have about 38" of wainscot, then walls up to about 7' 8", so not a lot of wall. I am going with a semi gloss on the wainscot, satin on the walls. I primed the wainscot with a 6" foam roller and it worked well. Any problem with using a foam roller on the walls?
Thanks for comments/opinions!
sirwired 01-17-2009 11:28 AM
The problem with using a foam on a wall, as best I can guess, is that the paint will have a tough time "flowing" out of the foam; instead you will have to squeeze. That WILL lead to inevitable roller marks. I am also guessing that a foam roller will hold less paint, making the job take longer.
Personally, I wouldn't risk $20 of paint to experiment with using an alternative to a $3 roller cover.
If you do try the foam on the wall, let us know how it turns out.
SirWired
Nestor_Kelebay 01-17-2009 03:16 PM
The ONLY time I ever use foam rollers is when I'm painting wood moldings because the foam roller puts a thinner coat of paint on. If I use a regular roller sleeve, then paint gets squeezed out of it and ends up dripping off the edge of the wood moldings.
I've seen larger foam rollers (like 7 inch foam rollers) and I'm wondering what people use them for? Walls?
markpainter 01-18-2009 10:28 PM
Yeah, foam is best for very thin coats so while there isn't a "problem" with using it I think it would take longer and isn't worth it.
Mark, MN Painters Network
7echo 01-19-2009 09:17 AM
thanks
Appreciate the comments.
I will use the 3/8 cover, don't want to make this an experiment.
Thanks again!
slickshift 01-19-2009 06:49 PM
Originally Posted by 7echo
...I will use the 3/8 cover
:thumbsup:
