Flood Floetrol - Painting - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 02:27 PM   #1
Rewards Points: 45
Flood Floetrol
Has anyone used this stuff?? I am looking to paint about 8 interior doors and I want to obtain as smooth a finish as possible. Is it worth using? Does it help obtain a better finish? I plan on using a foam roller and B Moore regal Select interior Semi Gloss white.
Thanks!
dschribs is offline   Reply With Quote
Old 06-26-2013, 03:15 PM   #2
I have used it when painting with BM impervo water based on crown molding and it made a world of difference. the paint glides on easier and it slows down the drying time to give the paint time to even out and the finish had no noticeable brush marks.
Old 06-26-2013, 03:35 PM   #3
Rewards Points: 45
Thanks!!
Old 06-26-2013, 03:43 PM   #4
DIY staff
Rewards Points: 7,174
I've used it also---you do not need much--the paint you have chosen is darn good without any extra help.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Jmayspaint (06-26-2013), user1007 (06-27-2013)
Old 06-26-2013, 04:58 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
Yea, don't use too much. It can thin the paint down to the point of affecting coverage. And will increase the chance of runs.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
oh'mike (06-26-2013)
Old 06-26-2013, 06:33 PM   #6
ltd
Rewards Points: 536
xim latex paint extender is a better product imho.get it at a real paint store like s/w
ltd is offline   Reply With Quote
Old 06-26-2013, 09:41 PM   #7
Rewards Points: 5,974
Have used both my vote Flotrol. Now having said that everyone is assuming you are using latex. If not you will need Penotrol for oil based.
The Following User Says Thank You to ToolSeeker For This Useful Post:
user1007 (06-26-2013)
Old 06-27-2013, 07:06 AM   #8
Rewards Points: 512
the stuff works great. i mainly use it when painting ceilings and the always turn out perfect no roller lines and a nice smooth flat finish.
princelake is offline   Reply With Quote
Old 06-27-2013, 11:19 AM   #9
Too Short? Cut it Again!
You did invest in a quality brush right? Purdy, Wooster etc.
All the paint conditioners like mentoned will not fix crappy brush bristles dragged and "feathered" lightly over your finish.
Old 07-01-2013, 09:26 PM   #10
Rubbin walls since'79
Brushjockey's Avatar
After I tried XIM latex extender I threw out the rest of the gallon of flotrol I had. That was over 5 years ago. Haven't looked back..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
chrisn (07-02-2013)
Old 07-02-2013, 12:08 PM   #11
Rewards Points: 4,792
I've never used XIM. Floetrol is just OK, IMO. It helps, but isn't a "night and day" experience as some others seem to have.
jeffnc is offline   Reply With Quote
Is the electric garage door opener popping the flood lights? Hardway Electrical 3 03-01-2013 05:58 PM
How to wire an exterior flood light to a new combination switch evm Electrical 6 02-01-2013 08:09 AM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 11:16 AM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
