Floetrol, Water, Paint - Ratio? -to Minimize Brush Strokes - Painting - DIY Chatroom Home Improvement Forum
Old 04-05-2009, 12:25 AM   #1
Floetrol, water, paint - ratio? -to minimize brush strokes
I'm painting my doors tomorrow and I wanna cut back on the heavy brush marks. What ratio or percent of floetrol, water, and paint do you use?
newbpainter is offline   Reply With Quote
Old 04-05-2009, 06:57 PM   #2
First off just use Flotrol, no water, use a high quality paint and brush. When it come to semi-gloss or satin paint don't skimp on what you spend. But I am a little bias since I sell Ben Moore. Products that have performed excellent in self leveling with out flotrol is Aura semi-gloss as well as Waterborne Satin Impervo. But I am sure there are other great products out there as well. As far as ratio's go, many painters go by feel but there is information on the back of the flotrol container. Good Luck....
BMDealer is offline   Reply With Quote
Old 04-06-2009, 04:07 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
With quality products,you should not need to add either one
chrisn is online now   Reply With Quote
Old 04-06-2009, 05:48 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
There are a lot of "high quality" products out there that do indeed benefit from Floetrol. These upper end paints like Duration and Accolade are based off a rapid drying Acrylic DTM formulation. Good luck getting a smooth finish without an additive. They dry so fast you see every stroke.
With Accolade I usually put 1-2 ounces per quart.
poppameth is offline   Reply With Quote
Old 04-06-2009, 07:12 AM   #5
There may be many high end products that benefit from adding Flotrol. But I will admit not being a painter and doing my own work with Semi-Gloss Aura with a very good stiff brush I had zero brush marks.....on 6 panel doors no less. Drys fast, yes, but levels quickly from my use.
Same result with Aura exterior, had a painting contractor say it looks sprayed on when you done.
As I said before don't skimp on the applicators as well as look at a good high end paint. Duration from what I hear is a good paint but Accolade has many mixed reviews.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Any good tops for keeping paint from drying on the sides of the brush? Jim S. Painting 16 02-13-2009 02:18 PM
Cutting - in Illinois G.C. Painting 11 11-24-2008 02:04 PM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 09:29 PM
