Flaws Visible In Darker Colors? - Painting - DIY Chatroom Home Improvement Forum
Old 12-11-2013, 09:35 AM   #1
Rewards Points: 2,072
flaws visible in darker colors?
After painting my entire house, the color I chose for the garage is the darkest. Do darker colors show flaws more than lighter colors? I don't know what this horizontal triangle flaw was, next to the entry door and I never saw it before until I started painting even tho I use this doorway a lot.
It's a garage so I'm not overly fussy but paint is expensive and I'd like it to look as nice as possible. I'm using SW Superpaint, in eggshell. I just sanded this spot and hope the 2nd coat covers it. (or minimizes it).
I think anymore work on it would just make it worse.
Startingover is offline   Reply With Quote
Old 12-11-2013, 10:51 AM   #2
Rewards Points: 13,254
What's that surface your painting?
Block, pored concrete, drywall?
Startingover (12-11-2013)
Old 12-11-2013, 11:23 AM   #3
custom user
Rewards Points: 150
Originally Posted by Startingover View Post
Do darker colors show flaws more than lighter colors?.
Yep. If you want to see every minor flaw on a car body, paint it jet black.
JasperST is offline   Reply With Quote
The Following 2 Users Say Thank You to JasperST For This Useful Post:
Gymschu (12-11-2013), Startingover (12-11-2013)
Old 12-11-2013, 11:48 AM   #4
Joe, My garage is Drywall. I wanted it to look more interesting than an ordinary garage. Maybe the builders scuffed the surface of the drywall when building this house?
Jasper, I have to follow thru since I paid for this pant, but I'll only do the front wall as you drive in. On cars, I don't think anything looks snazzier than a beautiful black polished car, but I don't clean my car so I'd never have black.
Old 12-11-2013, 11:57 AM   #5
If that's drywall then that's one really bad finishing job. Looks like one sheet got broken and no one bothered to tape it.
Old 12-11-2013, 12:01 PM   #6
joe,
should I leave it alone? I sanded it a bit.
I have orange peel spray. Would a little bit help? Or a bit of joint compound? (remember you're talking to an amateur.) (an over zealous amateur).
Old 12-11-2013, 03:59 PM   #7
Gymschu's Avatar
Rewards Points: 460
SO, that's going to be a major drywall fix if you want it to look right. Sanding or orange peel spray aren't going to make those cracks disappear. Even if they did, you would then have a mismatched texture look which would be even more noticeable. Being a garage, I say paint it and forget it.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 12-11-2013, 05:20 PM   #8
Rewards Points: 5,974
To fix it not a big deal. The big deal would be to match the texture I believe to try to do this would make it stand out and be a lot more noticeable than it is now.
Old 12-11-2013, 05:22 PM   #9
gymschu,
That's what I'll do. Forget about it. I'm just happy I have Superpaint. For some reason this gal. seems extra thick, but then I haven't painted for 6 months. Anyway, I'm sure it will cover as well as any paint.
thanks everyone.
The Following User Says Thank You to Startingover For This Useful Post:
Old 12-14-2013, 12:03 PM   #10
Rewards Points: 4,792
It looks like the darker paint is higher sheen than the white paint. Of course sheen paints will always show more flaws than flat paints.
jeffnc is offline   Reply With Quote
What colors go good with a light green? tina21 Interior Decorating 20 12-30-2015 05:58 AM
How much more difficult is it to use more colors? PaintBird Painting 75 04-23-2012 09:31 PM
Do darker colors appear more glossy? Achilles97 Painting 4 01-27-2010 01:26 PM
Sites to "virtually" change paint colors? Shpigford Painting 3 11-02-2007 07:10 PM
Ideas for shutter colors for sterling grey siding. patt Painting 1 05-23-2007 08:21 PM
