Old 10-12-2011, 03:16 PM   #1
Flat vs Semi Gloss Paint
When do you use Flat and when do you use Semi-Gloss Paint ?? What would you use inside an outdoor cabana ?
eastclinto is offline   Reply With Quote
Old 10-12-2011, 06:11 PM   #2
Gymschu's Avatar
Flat is for walls and ceilings, although I like Satin or Eggshell for walls. Semi-gloss is usually used for wood trim, doors, cabinets, etc. that have a lot of potential to get dirty or get fingerprints on them, etc. and where scrubbability is important. As for a Cabana, I'm not sure exactly what you would use to paint it.............I don't like flat because it attracts dirt like no other type of paint.
Old 10-13-2011, 09:10 AM   #3
Gymschu's points are on, but I would recommend at least an exterior satin. If it's by a pool, there's a lot of vapor surrounding pools.
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Smooth walls with flat paint...looks weird to me? TOTALN00B Painting 3 04-25-2011 06:42 AM
mixing flat and semi-gloss paint together Flt_Simulation Painting 11 01-06-2011 10:51 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
