Flat Over Semi-Gloss - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 04:19 AM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Originally Posted by christie5683 View Post
Couldn't you just use a paint with primer in it?
I understand that semi gloss is easier to clean but touch ups are very noticeable?
4 years ago, when this thread started, there was no such marketing scheme
http://buildipedia.com/at-home/painting/paint-vs-primer
Old 09-20-2012, 08:48 AM   #17
Rewards Points: 5,974
TO prime or not to prime that is the question. Imho it would be a waste of time and money to prime. I know i keep saying this but I believe it to be so true, the key is a good quality paint. And please stay away from the newest marketing gimmick all in one, it doesn't work.
Old 02-24-2013, 02:12 PM   #18
You can sand less if you prime after sanding. My wall texture isn't totally smooth (not for decorative reasons - it just turned out that way after several roller coats of paint over the years) and to get the sand paper in every little dimple may be difficult and messy. I'm not sure whether I'll prime. If I had a really good sander with vacuum attachment and an appropriate vacuum I'd probably just sand.
Dorado is offline   Reply With Quote
Old 02-24-2013, 03:56 PM   #19
Gymschu's Avatar
Rewards Points: 460
Original post was from 2008 .......I think they have solved their problem by now.....at least I hope.
Gymschu is online now   Reply With Quote
Old 02-24-2013, 04:26 PM   #20
With some, you can't take that for granted. BTW, Dorado, what are working on right now, refresh.
Old 02-24-2013, 04:53 PM   #21
I have to paint a bedroom and hallway that have semigloss paint and I want to use something less glossy so the next time I paint it sanding or priming won't be necessary. My plans are to chip off a bunch of pealing paint in the bedroom, then spackle at least some of it, and clean with TSP substitute. Then maybe I'll sand and clean with a damp cloth or more TSP. Then maybe I'll prime before painting with latex. I think I'll buy a sander because I have a little drywall work, but I don't think I'll be spending hundreds.
Old 02-24-2013, 08:46 PM   #22
cdaniels's Avatar
Don't use a power sander on drywall my friend. Use paper or sanding screens, some use a pole sander but I like to sand by hand.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 3 Users Say Thank You to cdaniels For This Useful Post:
chrisn (02-25-2013), Gymschu (02-25-2013), ToolSeeker (02-26-2013)
painting trim with semi gloss paint sninny Painting 10 09-21-2012 05:33 AM
semi gloss sheen problems Pawl Painting 5 03-15-2008 11:29 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
