Flat Drywall Patch - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 12:07 AM   #16
cdaniels's Avatar
Satin or eggshell both have a sheen(usually about half the sheen of semi-gloss)and both are washable.They don't show the imperfections that a semi-gloss shows because of the lower sheen.But of course,if you like the semi-gloss finish then by all means use what you like.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 01-31-2013, 12:09 AM   #17
Registered User
Rewards Points: 4,926
How to resize photos to post them here.
Gary
Gary in WA is online now   Reply With Quote
Old 01-31-2013, 03:25 AM   #18
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
Originally Posted by christina0806 View Post
I have always used semi gloss on my walls. It washes good that is why I won't use flat it is dull looking and doesn't wash well. What else would I use if I didnt use semi gloss?
All quality flats are washable
chrisn is online now   Reply With Quote
Old 01-31-2013, 03:49 PM   #19
Ok I didn't realize you could wash a flat paint that well. I still don't like flat paint because it looks so dull to me.
christina0806 is offline   Reply With Quote
Old 01-31-2013, 04:05 PM   #20
Christina, there are a couple of options between flat and semi-gloss. I've been rolling walls for a long time and I would dread rolling semi-gloss on anything but a bathroom. It's that difficult and unforgiving to work with, even for a pro. Even satin, just below semi, is a bit tricky and finicky. Eggshell and flat enamels, or mattes, are washable and have a slight angular sheen. Velvets, low lusters are some others. All washable and far easier to work with. They're easier on the rods and cones also.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
christina0806 (01-31-2013), ToolSeeker (01-31-2013)
Old 01-31-2013, 11:42 PM   #21
Ok thanks. I am way to far along to change my paint now, pretty much done. BUT when this color gets old to me and I decide to paint again I think I might try something with less gloss maybe eggshell. I have rolled over my patch about 5 times today letting it dry quite well between times and it does look a little better than it did. What causes the little air bubbles in the paint? I got a few on the patch, is it because maybe it wasn't dry enough one time? I just poked them with a needle and they are pretty much gone.
Old 02-01-2013, 04:08 AM   #22
chrisn's Avatar
Rewards Points: 150
Old 02-01-2013, 04:49 AM   #23
I just figured out where I got the impression you were using flat, it's the title of the thread. I knew I wasn't crazy. After you corrected me I scoured this thread for the word flat, never realizing it was the title.
Sand down edges of drywall patch panel for tape? patchtaper Drywall & Plaster 2 12-15-2012 10:53 PM
Repainting over flat white latex paint on drywall. etherag Painting 37 03-25-2012 04:21 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
How to patch a drywall such that it can hold some weight annu Drywall & Plaster 8 11-30-2008 11:42 AM
