Flaky Paint On Dry Lining - Painting - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 10:15 AM   #1
Flaky paint on Dry Lining
We have seriously flaky paint in our bathroom and it's on Dry Lining! I'm guessing that's because when the Dry Lining orinially put up the buidler didn't treat the Dry Lining before they initially painted the walls.
A lot of the paint comes off with a scrapper but there are parts where the paint hasn't flaked and it's very difficult to get off. It also leaves a ridge at the edge of the paint. Is there a way of removing this paint from Dry Lining?
Also, when I've got all the paint off can you suggest what I should use to prime the Dry Lining so that it'll take the paint without flaking?
Thanks for your help.
Dave
davidthomas is offline   Reply With Quote
Old 03-13-2011, 11:29 AM   #2
Dave, firstly, what the heck is dry lining? If it's drywall you mean, the flaking is being caused by steam, which will happen whether the builder primed or not. They used a flat finish which is par for the course in new construction these days. Scrape the loose off, prime the surface with a good latex primer. Then spackle the edges to feather them out. Reprime the patched areas. Then apply two coats of a latex finish with a minimum satin sheen or a specialty bath paint, such as Zinsser Perma-White or BM Bath and Spa. Make sure you dust the surfaces after you sand and don't waste time trying to remove any old finish that is sound, just prime over and spackle.
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
