Flaking External Walls - Painting - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 01:09 PM   #1
Flaking external walls
Hi I live in an old house in the countryside; subject to very wet, windy weather. The walls are solid and rendered. some of the external paintwork is peeling off due to previously using cheap paint. I need to stabilize these walls prior to re-painting with 'Dulux Weathershield Masonry Paint'. I had thought of jet-washing all the very loose paint off, allowing the wall to dry and applying a 'Unibond' and water undercoat. Does anyone have any other, better ideas? Back to top
peakpilgrim is offline   Reply With Quote
Old 04-09-2010, 01:18 PM   #2
Military Mom of 4
Snav's Avatar
Well - you have damp inner walls and peeling paint on the outside.
A brick home?
I'm no pro in your area of issues but it seems to me as if your problem is bigger than you realize and the external and internal problem is connected. If your walls have become saturated thoroughly due to humidity and rain-exposure and so forth then just treating them likely won't take care of the issue.
So, I'd try to really get to the bottom of your entire problem before spending money and time on something that might not work at all. . . . and I'll let others give their ideas for why you might be experiencing these issues.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-09-2010, 05:24 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
What are the walls made of?
slickshift is offline   Reply With Quote
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 09:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
