Fixing The Walls... - Painting - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 09:35 AM   #1
Rewards Points: 264
fixing the walls...
Repainting a room as part of a remodel. This room is small, about 11' x 12'. The walls are in bad shape-lots of little nicks, dings, bad drips from the previous paint job(not me!). The walls are almost what I would call a texture finish, maybe they used a 3/4" nap, it is very bumply. So, I sanded the walls down with 100 grit(used a random orbit attached to the shop vac, nearly no dust) and am touching up the dings and dents with mud. Problem is, all the touched up spots will be smooth, the rest still has some texture. I want a consistent finish. So, how do I handle all the recently repaired smooth parts? Hit those areas with some primer on a thicker roller first, then do 2 top coats?
Comments are appreciated!
7echo is offline   Reply With Quote
Old 04-18-2009, 10:09 PM   #2
Rewards Points: 160
If you consider all the time repairing and patching and sanding the wall...what about just replacing the drywall?
hellothere123 is offline   Reply With Quote
Old 04-19-2009, 06:41 AM   #3
Rewards Points: 264
I considered that, but the cost was better to just work on the existing walls.
Old 04-19-2009, 12:49 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
When walls get to that point, we sometimes use a 1 part joint compound, 2-3 parts paint mix. It's tricky to apply, especially the cutting-in, but it will give you nice uniform finsh. You can also try a skim coat of joint compound on the walls.
Old 04-19-2009, 01:17 PM   #5
Rewards Points: 506
I have been able to "beef up" the stipple on smooth patches in the past by rolling with a nice, thick, stain blocking primer (SW Prep Rite ProBlock Latex) before topcoating. I think your plan to use a 3/4" nap roller might be a bit much. Start with a 3/8" or 1/2" and see how it goes.
SirWired
sirwired is offline   Reply With Quote
Old 04-20-2009, 07:16 PM   #6
Couple of options....USG Tuff-Hide which is a sprayed on primer/mud finish. Very similar to skim coating. Other option would be BM SuperSpec 270-00 Hi-Build primer. This product is designed for solving minor wall imperfections.
BMDealer is offline   Reply With Quote
Old 04-21-2009, 11:27 AM   #7
Rewards Points: 506
I think a high-build primer is overkill just to simulate roller stipple. A thick stain-blocking primer has worked great for me.
SirWired
Old 04-21-2009, 11:48 AM   #8
The hi-build is not designed to simulate roller stipple is design to fill voids and level off minor defects in tape joints. The product is self leveling and shouldn't give you any orange peel that is if a low nap roller cover is used.
Old 04-21-2009, 08:02 PM   #9
Rewards Points: 264
Thanks for the comments!
What about something like Zinsser 123 primer? Would that be a good option? I have several gallons.
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Need step by step instructions for fixing walls... Chianti Painting 7 06-20-2008 07:04 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
