Old 07-26-2006, 11:41 AM   #1
Fixing a wallpaper removal mishap
Unfortunately, someone who was "helping" remove wallpaper with a scraper also removed a huge chunk (about 11x27 inches) of the drywall outer layers down to the cardbard-like center. (His "help" was my inspiration to find another way to remove wallpaper)
It seems to be a bigger area than I can cover with compound. I mean, I can cover it it with compound but I don't know if I can sand it to look flat.
Do I do the best I can with compound? Or do I cut out the affect piece and replace it? I'm in the process of trying to fix it with compound but any suggestions would be gratefully accepted.
Susan
applesusan is offline   Reply With Quote
Old 07-26-2006, 02:02 PM   #2
They're all fixer-uppers
J187's Avatar
Whereas the area is so large, If it were me, I would cut out the damaged section back to the nearest studs on each side and replace it with a patch piece of drywall. Treat the patch drywall like any other drywall job where you tape the joints and mud. In this case, you may want to use the self stick kind of tape but either will do. Sand and repaint. Especially where you are already in the process of finishing the walls and removing wallpaper, it really won't be much more work and it will be a strong replacement.
J187 is offline   Reply With Quote
Old 07-26-2006, 07:52 PM   #3
your quickest option would be to mud over the area its just as easy especially if you have a 12 inch blade to put down the area when your smoothing out before drying. As for making it level just take your time sanding you should be able to fan it out.
lxdollarsxl is offline   Reply With Quote
Old 07-26-2006, 09:02 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
If it's not too deep the "skim coat" of compound should work
The proper procedure would be to primer, repair, sand smooth, re-primer, paint
I'd use a primer specifically for drywall repair, such as Gardz
slickshift is offline   Reply With Quote
Removing wallpaper and then painting applesusan Painting 7 02-24-2008 05:32 PM
We need your opinions Boatnuts Remodeling 31 02-22-2007 11:41 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 06:41 PM
