I'm guessing based on OPs attitude no one else will take the time (wrong on that one, wasn't I?) I'm bored and hate ignorance.
Originally Posted by cvcman
Humm explain something to me.... If the water in the mud didnt bubble it how can the water in the paint IF I used laytex get thru the mud and bubble it ?
The ACRYLIC RESINS in the LATEX paint forms a skin. The moisture in the LATEX paint is WATER. Water trapped behind the acrylic skin when in contact with the raw drywall can result in bubbles. Water in the mud may have bubbled but there was nothing to trap it, so they dissipated.
And...how come oil paint will seal it and not bubble the paper ?? I would think the mositure in the wet oil paint would bubble too ?
OIL paint 'moisture' is OIL in old fashioned oil paint (duh, right?). Modern oil paint is really alkyd paint that is made with alcohols and organic acids. So the 'moisture' in oil based paint BEHAVES chemically differently than latex paint. The 'oil' will not cause the same off-gassing that water causes.
I had these walls wet like crazy while washing them and none of these spots were bubbling...
Oh well
See above; as to why you didn't see bubbles when washing the walls.
Good luck. Hope some actual explanation helps.
