Fixing A Painting Problem - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 09:50 PM   #1
Unhappy
Fixing a painting problem
I recently painted my kitchen cabinets. I chose a dark green. I like the color, but it is a bit bright under some light conditions, and it shines too much. I'd like an easy fix to this. I think that there must be a stain or some other treatment that I can just put on as a last coat that will dull the color and darken it a bit. Any ideas or experience with this? Thanks, Silvia
sbigatti is offline   Reply With Quote
Old 10-22-2007, 09:56 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The solution is to use as the last coat, a coat of paint or enamel with less sheen and a shade (or a few shades) darker
slickshift is offline   Reply With Quote
Old 10-23-2007, 11:29 PM   #3
Paint/Faux Artisan
Da Vinci's Avatar
Get a quart of Zar Polyurethane flat and mix some umber colorant in it- use it as a glaze right over the green- the umber will soften the green and the flat leaves a lower than satin sheen. You may need to experiment with how much umber to add, also, a little thinner may help the glaze....
Bob
Piedmont CA Painting Contractor
Da Vinci is offline   Reply With Quote
Old 10-24-2007, 02:11 PM   #4
Smile
Thanks to both of you! I'll try and and report back, Silvia
painting my floor Eli Flooring 3 03-20-2011 05:11 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Hairline Cracks after painting parasailing Painting 8 07-24-2006 12:47 AM
Painting a problem wall Cbear1883 Painting 1 04-24-2005 03:13 PM
Need opinions on fixing an outlet problem ryaniniowa Electrical 4 03-20-2005 10:06 PM
