Fixing Little Blemishes After The Wood Has Been Primed - Painting - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 05:59 PM   #1
Rewards Points: 35
Question
fixing little blemishes after the wood has been primed
I am stripping the exterior of my house down to the wood, repairing the wood with bondo and then priming it with Sherwin Williams oil primer. The problem is I usually see many a few missed blemishes after I have primed it. I have been told that bondo shouldn't be used over primer. What should I use? I am looking to have this last as long as possible. Is something basic like Elmer's carpenter's interior exterior wood filler good? Or is there something better?
skiposwald is offline   Reply With Quote
Old 09-25-2009, 03:27 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Why not?
Old 09-25-2009, 08:10 AM   #3
Rewards Points: 35
I don't know. I called the manufacturer and that is what they told me. Do you disagree?
Old 09-25-2009, 11:44 AM   #4
Rewards Points: 35
Anyone? Bueller?
Old 09-25-2009, 03:16 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
I would thin you could do it, but if not, use spackle for holes and caulk for cracks.
Old 09-25-2009, 05:42 PM   #6
chrisn's Avatar
Rewards Points: 504
I guess I would not argue with the manufacturer, but bondo was not made for wood anyway, so I don't know.I think I would use exterior spackle for small areas, this is what it is made for,as Matthew said.
Old 09-29-2009, 10:11 AM   #7
Rewards Points: 35
So very very few DIYers fix blemishes after priming, eh? I have asked so many people about this, and most people don't even bother, or they just any product that is sitting around. I am surprised. My yard is so small that my paint job is in my face everyday. It would be too annoying to look at if I just left it as is.
Old 09-29-2009, 01:23 PM   #8
chrisn's Avatar
Rewards Points: 504
Matthew already posted to use exterior spackle, what more do you want?
Old 09-29-2009, 09:29 PM   #9
Rewards Points: 35
I wanted to post that comment. I hope that is ok with you, this being a discussion board and all.
Old 09-29-2009, 10:42 PM   #10
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
There is Bondo specifically for wood repairs, but you should sand the repair spot first removing any paint and/or primer for proper adherence of the Bondo. If you have minor repairs or nail holes it would be more efficient to use an exterior spackle, such as DryDex, DryDex works well for interior and exterior, drys fast and easy to sand. Whether you choose Bondo for wood or Drydex would depend on the repair, but you'll still have to prime over it after sanding. Sherwin Williams sells the Bondo for wood repair.
housepaintingny is offline   Reply With Quote
Tags
wood filler bondo elmer's
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Fixing a wood door... CuCullin Carpentry 6 10-27-2007 06:46 PM
