Fixin' Up The Walls ? - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2007, 04:42 PM   #1
Greetings--
Bedroom walls. Gloss/simi-gloss purple (ok ok-- violet) paint.
Nail holes, popped sheetrock nails, ect. Light texture under 2-3 coats of paint. Signs of previous nail hole repairs.
I"d like to patch up the holes/dings, re-texture it and then paint it.
== Can I just patch it, roll/spray light texture and paint ?
OR
== Do I have to prime it, then texture then paint ?
OR
Piney is offline   Reply With Quote
Old 02-26-2007, 05:48 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Piney View Post
Greetings--
OR
OR
This is from experience doing precisely the same kinds of repairs:
Perform you drywall patch work.
Fix those bad older patches too.
Apply your texture right over everything. (It will take longer to dry because of the paint).... Apply a primer over all the surfaces.
Paint away....
- Build Well -
Old 02-26-2007, 08:33 PM   #3
Any particular type/brand of primer you'd suggest ??
Old 02-26-2007, 08:36 PM   #4
We like the latex based Kilz for stains. Tougher stains - go with the oil based Kilz...
- Build Well -
Old 02-27-2007, 12:49 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
If your finish paint brand also offers a sander/primer/sealer, I've been told by pro painters to go with that for better bonding, such as Benjamin Moore SPS for priming for their Benjamin Moore paint.
I've also used a lot of Kilz, which works great, but the oil-based Kilz fumes will knock you out. I also use the latex BM SPS and BM paint, which doesn't have fumes.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-27-2007, 04:48 AM   #6
Originally Posted by Mike Swearingen View Post
....but the oil-based Kilz fumes will knock you out....
Yep...that is the bad part of it, we only use that stuff as a very last resort for the really tuff staining issues..
- Build Well -
Old 03-01-2007, 08:02 PM   #7
You folk are mentioning using KILZ in relation to covering stains. There arent stains on thee room' walls- just small repairs and old gloss/semi-gloss paint.
Im assuming that a latex Kilz is still the primer to use over the fixed and re-textured walls eh ?
Thanks again for the answers !!
Old 03-01-2007, 08:19 PM   #8
Tired, Cold, and Damp
slickshift's Avatar
I wouldn't recommend it
It's really not very good
It has a high failure rate
Don't get me wrong, the oil-based Original Kilz is great
All other products (latex) from them are...not something I'd recommend
You would do much better with the appropriate Zinsser, Ben Moore, or Sherwin Williams, primer
slickshift is offline   Reply With Quote
Old 03-01-2007, 08:40 PM   #9
Yes, you have a point there. The latex kilz/ is actually very 'mild' for a product that claims serious 'stain-killing' properties....
- Build Well -
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 06:55 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
