Old 06-06-2012, 12:36 PM   #1
fix eggshell flashing
My builder painted my new drywall and there is quite a bit of flashing and I'm wondering about the best way to fix it.
It was new drywall.
He did not use a primer.
He used Valspar premium eggshell paint (medium beige color).
He sprayed with airless sprayer and backrolled.
Now you can see flashing where the mud and paper have different sheens.
Will additional coats of paint eventually fix this issue if I use the appropriate technique (long strokes in one direction painting dry to wet)?
OR will I need to do something more drastic?
88bomber is offline   Reply With Quote
Old 06-06-2012, 03:04 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
First fix, your builder should find a painter.
And that painter should fix it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 06-06-2012, 03:38 PM   #3
Additional coats may fix it - might be better to do a coat of quality tinted primer/sealer and one more coat of eggshell on top of it.
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
88bomber (06-06-2012)
Old 06-06-2012, 04:35 PM   #4
Matthewt1970's Avatar
No sense in priming now. One coat of anything will never be enough on bare drywall. One more coat "might" do it but that is the exception, 3 coats is almost always the rule.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Old 06-06-2012, 05:04 PM   #5
My point is- did the builder do this- then it is on him.
Or is it the poster- using the builder did it line?
Whoever did it didn't know much.
Matthew on the other hand, does.
Old 06-06-2012, 05:22 PM   #6
paper hanger and painter
chrisn's Avatar
right
Eggshell Finish Confusion fjmartinez Painting 5 05-24-2012 09:34 AM
Re-roofing: flashing question prb_nearnorth Roofing 9 05-01-2012 12:42 AM
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing 6 03-10-2011 04:19 PM
Flashing repair Squash_Pro Roofing 9 05-07-2010 01:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
