#1 |
First time painting woes -- help!
Hi, I just started painting for the first time a new place that I got and seems I already made a few mistakes. I did some more research now and am realizing I made some pretty bad mistakes. Hopefully there is a way to fix it. I basically have three problems:
First, I I bought latex paints and tried to clean them with paint thinner. This latex paint/paint thinner combo when down the sink. Everywhere I look I see that it was a big mistake. Is there anything that I can do to fix it? In the future, from what I've read in books and online, I just need soap and water to clean the brushes/paint pans. I'm still not sure if I can pour this down the sink though? Now that I have paint thinner (and mineral water -- I bought that too) is there anything that I do need it for? It sounds like I really only needed it for oil-based paints. The guy who sold me the mineral water said I could use it to clean the walls. Is this safe to use on latex paint walls? I don't want to strip the walls, just something to clean it. From what I've read, this can simply be done with some kind of detergent. I really appreciate any help that you can give! Thanks! Sam |
#2 | |||||
Tired, Cold, and Damp
First time painting woes -- help!Quote:
Or are you worried about stopping up your drain? Or enviromental issues? Believe it or not disposal of thinner in the waste water is actually the recommended method of disposal in many circumstances You might not be one of those, but what's done is done, and I don't think you could've messed anything up too bad with a small amount of thinner if you are not Quote:
I actually just use water, no soap I also tend to line the paint trays/buckets rather than clean them, but I am pretty cheap and have been known to clean the liners...lol Quote:
#3 | |
Yes Master
#4 |
I guess that I am the worst then...I have been known to toss not only the liners, but the pails, the brushes (red paint), the rollers (pretty much all the time), and the dropcloth. I am wasteful, I know, lazy as well. I just hate cleaning the stuff. But that should make the liner tossers feel better
#5 | |
slickshift, thanks for all of your help! I feel better knowing that it can be done. I think my sink may be draining a little slow because of the paint, but as long as it won't cause any other problems I'm breathing easier.
#6 | |
It's a different animal I would stick to the TSP or Dirtex or similar Unless the paint instructions state to use the MS specifically for clean-up or wall prep, and that would mean it's not latex paint (that would be unusual) The latex should not block up the sink, it's made to be washed down the drain Some more hot water should clear it up I'd also consider using a different paint shop No offense to them whatsoever, but as helpful constructive criticism, they should have set you up a little better Please don't hesitate to ask here if you have any more questions PS hold on to the spirits, some day you may use a glue or sealer or special paint and spill some, and it'll say under "clean-up" on the label....mineral spirits We never read that "clean-up" part until it's too late |
#7 |
slickshift, thanks again! Just spent the weekend painting and though we're not finished, it's been good steady progress. I'll keep the mineral spirits and paint thinner in the closet for one of those days. Thanks again! This has been really helpful.
#8 | |
Contractor
I thought I was the only one who cleaned liners!
Regards, Ken Walker |
#9 |
Paintnewbie:
Good steady progress sounds good! |
#10 | |
-No Wait- I'm environmentally conscious Reduce Reuse Recycle |
#11 |
What is the best way to clean roller sleeves? I've been trying to squeeze them out under hot water, and even after doing this for 10 minutes, I feel like there's a lot of paint left in there...
Waste not, want not. |
| Display Modes | |
| First Time Home Buyer Woes | Jdelles | General Discussion | 9 | 10-12-2010 08:43 PM |
| Garage drywall painting | haylo75 | Painting | 18 | 11-12-2007 09:13 PM |
| couple questions about painting on different surfaces | joeyboy | Painting | 3 | 08-19-2007 03:33 PM |
| Painting exterior of house | crebive | Painting | 2 | 05-27-2006 12:53 PM |
| Novice: Painting lighter colour over darker | psd99 | Painting | 5 | 01-18-2006 09:24 PM |
