Finishing Wood Banister - Painting - DIY Chatroom Home Improvement Forum
Old 05-16-2008, 12:03 PM   #1
Finishing wood banister
I just restained my wood banister and am wondering the best product to use for a clear durable top coat. Any suggestions would be greatly appreciated.
Thanks.
digexpressions is offline   Reply With Quote
Old 05-17-2008, 10:20 AM   #2
Jay123's Avatar
We've used the Minwax poly (NOT the water based version) with great results. I'm partial to the satin finish (low sheen) but you may prefer a higher gloss, which they have as well.
I'll usually put 3 coats of poly on, sanding VERY LIGHTLY between coats (after it has dried, of course) with either 220 or 320 grit sandpaper.
What you're trying to accomplish with the sanding is to knock any nibs (small bumps) off the finish coat before applying subsequent coats. DO NOT sand through the new topcoat, just enough to knock down the small bumps.
By sanding LIGHTLY between coats, your finish coat will be nice and smooth to the touch, which is important on a handrail.
J
P.S. Can you guess that I may have sanded a little too aggressively the first time I did this?
Jay123 is offline   Reply With Quote
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
finishing a basement- metal tracks & wood studs sweep the leg johnny Building & Construction 4 03-09-2007 04:05 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 07:54 PM
