Finishing Exposed Brick Wall--which Product To Use? - Painting - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 12:21 PM   #1
Rewards Points: 1,062
Question
Finishing exposed indoor brick wall--which product to use?
I am looking for ideas which product to use to finish my exposed indoor brick wall. I want it a little shiny but not too much. The house is 103 yrs old and I have just removed the plaster, cleaned the brick and tuckpointed--it was a Sisyphus' job so i REALLY want it to look beautiful.
Polyurethane, varnish, shallac, or something fourth? I know little about paints.
See attached. Also note I haven't brushed and cleaned the residue from new mortar--is water and brillow pads OK for that or should i use some special solution (e.g. muriatic acid or TSP). I also heard vinegar works well. So many options. Please advise.
Thanks in advance
Old 12-22-2012, 12:24 PM   #2
Rewards Points: 2,516
Originally Posted by amakarevic View Post
I am looking for ideas which product to use to finish my exposed brick wall.
Exposed to the outside elements or exposed to inside?
See attached.
attached what??
hammerlane is offline   Reply With Quote
Old 12-22-2012, 12:25 PM   #3
Indoor, sorry
attached what??
Sorry, the attachment sending failed from my Android. Working on fixing it
Old 12-22-2012, 12:29 PM   #4
Done. please check out
Old 12-22-2012, 01:28 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
Interesting- my first q would be why put anything over it at all- seems like it is pretty nice looking as is, and if you coat it with a clear ,even product it will lose the real brick look and look- well, coated.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
joecaption (12-22-2012)
Old 12-22-2012, 01:34 PM   #6
thanks for the compliment. i though another reason would be to protect it, maybe the texture of varnish or such makes it look nice longer. but i also like moderate shine... moderate
Old 12-22-2012, 01:56 PM   #7
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
We use H&C masonry sealer from Sherwin Williams on interior and exterior brick to protect and seal the brick. We have used this product on several historical restorations that have had brick too.
This product dries clear and you can not tell that a sealer has been applied to the brick.
housepaintingny is offline   Reply With Quote
The Following 2 Users Say Thank You to housepaintingny For This Useful Post:
amakarevic (12-22-2012), Gymschu (12-22-2012)
Old 12-22-2012, 02:37 PM   #8
How is this, for example?
Finishing exposed brick wall--which product to use?-forumrunner_20121222_153759.jpg
Old 12-22-2012, 02:43 PM   #9
Concrete & Masonry
Rewards Points: 636
Personally, it looks like there's alot of mortar residue left on the surface. Not sure if it's from tucking, or from the original plaster. I would undoubtedly try to wash it down thoroughly before any kind of sealer. Start with something weak, like vinegar & water and plenty of elbow grease. If that doesn't work, I'd look at a product like "Detergent 600" from Prosoco. There's no way I'd use muratic acid inside a residence.......
As for sealing it, if it is currently inhabited, you'll likely have to use a subtle oil based (try boiled linseed oil) or a water based product.
jomama45 is offline   Reply With Quote
Old 12-22-2012, 02:56 PM   #10
Yes but it can be cleaned, no doubt. I think I will first quickly go over with a cup brush on a 4.5" grinder to remove big pieces so they don't smear around by wet cleaning.
Old 12-22-2012, 04:18 PM   #11
Rewards Points: 14,290
Shiny brick
Old 12-22-2012, 04:49 PM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
I'm with brush here, what do you need to protect it from if it's inside?
Old 12-22-2012, 04:51 PM   #13
chrisn's Avatar
Rewards Points: 606
Attachment 62386
NO NO and again NO, why take the chance of ruining all that hard work with an inferior crappy product?
The Following User Says Thank You to chrisn For This Useful Post:
Brick Wall Fireplace Questions mjoe Remodeling 3 12-03-2012 07:40 AM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
DIY fireplace remodel gone awry - impenetrable brick wall shawnad73 Building & Construction 8 08-23-2010 08:52 AM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 10:00 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
