-   -   Finishing exposed brick wall--which product to use? (http://www.diychatroom.com/f4/finishing-exposed-brick-wall-product-use-167131/)
amakarevic 12-22-2012 01:21 PM
Finishing exposed indoor brick wall--which product to use?
1 Attachment(s)
I am looking for ideas which product to use to finish my exposed indoor brick wall. I want it a little shiny but not too much. The house is 103 yrs old and I have just removed the plaster, cleaned the brick and tuckpointed--it was a Sisyphus' job so i REALLY want it to look beautiful.
Polyurethane, varnish, shallac, or something fourth? I know little about paints.
See attached. Also note I haven't brushed and cleaned the residue from new mortar--is water and brillow pads OK for that or should i use some special solution (e.g. muriatic acid or TSP). I also heard vinegar works well. So many options. Please advise.
Thanks in advance
hammerlane 12-22-2012 01:24 PM
Originally Posted by amakarevic (Post 1078022)
I am looking for ideas which product to use to finish my exposed brick wall.
Exposed to the outside elements or exposed to inside?
See attached.
attached what??
amakarevic 12-22-2012 01:25 PM
Indoor, sorry
attached what??
Sorry, the attachment sending failed from my Android. Working on fixing it
amakarevic 12-22-2012 01:29 PM
Done. please check out
Brushjockey 12-22-2012 02:28 PM
Interesting- my first q would be why put anything over it at all- seems like it is pretty nice looking as is, and if you coat it with a clear ,even product it will lose the real brick look and look- well, coated.
amakarevic 12-22-2012 02:34 PM
thanks for the compliment. i though another reason would be to protect it, maybe the texture of varnish or such makes it look nice longer. but i also like moderate shine... moderate
housepaintingny 12-22-2012 02:56 PM
We use H&C masonry sealer from Sherwin Williams on interior and exterior brick to protect and seal the brick. We have used this product on several historical restorations that have had brick too.
This product dries clear and you can not tell that a sealer has been applied to the brick.
amakarevic 12-22-2012 03:37 PM
1 Attachment(s)
How is this, for example?
Attachment 62386
jomama45 12-22-2012 03:43 PM
Personally, it looks like there's alot of mortar residue left on the surface. Not sure if it's from tucking, or from the original plaster. I would undoubtedly try to wash it down thoroughly before any kind of sealer. Start with something weak, like vinegar & water and plenty of elbow grease. If that doesn't work, I'd look at a product like "Detergent 600" from Prosoco. There's no way I'd use muratic acid inside a residence.......
As for sealing it, if it is currently inhabited, you'll likely have to use a subtle oil based (try boiled linseed oil) or a water based product.
amakarevic 12-22-2012 03:56 PM
Yes but it can be cleaned, no doubt. I think I will first quickly go over with a cup brush on a 4.5" grinder to remove big pieces so they don't smear around by wet cleaning.
joecaption 12-22-2012 05:18 PM
Shiny brick:eek:
chrisn 12-22-2012 05:49 PM
I'm with brush here, what do you need to protect it from if it's inside?
chrisn 12-22-2012 05:51 PM
Attachment 62386
NO NO and again NO, why take the chance of ruining all that hard work with an inferior crappy product?
