Finish For Crown Moulding - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 10:35 PM   #1
finish for crown moulding
Just had crown moulding put in. I have flat ceiling in white and Flat wall in a brown tone. Not sure what is better, to use to use flat or semi-gloss for the moulding. Plan on using the same white as on the ceiling. Thanks!
jacky is offline   Reply With Quote
Old 01-08-2012, 10:48 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I've never seen trim painted flat.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-08-2012, 10:48 PM   #3
Learning Things Every Day
Jay 78's Avatar
My suggestion would be satin.
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-08-2012, 10:51 PM   #4
Rewards Points: 12,886
You want the crown to stand out not blend in to the ceiling.
I use semi gloss but ha that's me.
Old 01-09-2012, 04:19 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
The crown is usually painted the same as all the rest of the trim( semi gloss for me)
Old 01-09-2012, 05:48 AM   #6
ARC Painting's Avatar
put it this way: it depends on your taste and decor, either way will work.
Flat crowns will make it look like they are 'part of' the ceiling, and blend in more. It is a more subtle route. Use the same paint as on ceiling, you want it to match.
crowns in semi-gloss (or satin, etc.) would be to tie into the rest of the trim (use same colour as trim)
Crowns will be more apparent this way; do this if you want to highlight them.
Hope that helps!
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
The Following User Says Thank You to ARC Painting For This Useful Post:
Jay 78 (01-09-2012)
Old 01-09-2012, 11:01 AM   #7
Disabled wood vet
titanoman's Avatar
All that hard work to hang crown and then try to hide it by making it blend in with the ceiling?
Old 01-09-2012, 01:48 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
Some of the worst adhesion problems I have seen is when someone slops flat ceiling paint on a previously enameled crown- really hard to scrape that crap off the curve...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-10-2012, 08:07 AM   #9
true, true.
but if they are installed poorly, a flat finish makes them look better!
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 08:51 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
