Finding The Right Air Compressor - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 12:13 AM   #1
Finding the right air compressor
I just recently purchased an hvlp gun that requires an air compressor with 10 cfm's at 20 psi. The problem I am having is finding the correct compressor to meet those specs. Preferably portable.
johnnyrob is offline   Reply With Quote
Old 07-17-2010, 04:51 AM   #2
you won't find a pancake that can run a real hvlp gun. for $300ish you can buy a craftsman 33gal or one of the similar oil lube compressors at depot or lowes. if you have to stay on 110v it's really your only shot.
racebum is offline   Reply With Quote
Old 07-17-2010, 06:31 AM   #3
DIY staff
Rewards Points: 7,174
I run my HVLP sprayer with a turbine,not a compressor---Campbell Hausfield --
The turbine is the size of a tool box and uses 110 volts.--Mike--
Google HVLP turbine--lots to see.
Old 07-17-2010, 08:24 AM   #4
I will agree with oh`Mike on this one.
mark942 is offline   Reply With Quote
Old 07-17-2010, 02:51 PM   #5
can you run regular hvlp guns on a turbine? i've only seen the complete kits sold
Old 07-17-2010, 03:33 PM   #6
DIY staff
You need to check with the gun manufacturer. A lot of guns,,all that have the big connector,
are designed to run off a turbine.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Please help: blown fuse, slow compressor fan, and hissing noise from compressor frazwr01 HVAC 10 06-27-2010 10:08 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 02:10 PM
