Filling Small Defects In Alkyd Primed Trim: What To Use? - Painting - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 12:25 PM   #1
Rewards Points: 188
Filling Small Defects in Alkyd Primed Trim: what to use?
After wood trim is alkyd primed (in this case Ben Moore Underbody Alkyd Primer #217) small surface defects that were missed become visible and need patching.
What product is used? Spackle? Solvent base Wood Filler? Joint compound?
Also when moving on to painting: do you guys generally do all the coats of wall painting first, complete that and move on to painting trim and doors, or do you apply the first coat of wall paint followed by first coat of trim paint…..second coat of wall then second coat of trim?
Is there an advantage to one sequence over the other? Ease of cut in, ease of touching up painting errors, etc.
Lovegasoline is offline   Reply With Quote
Old 12-19-2009, 01:22 PM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
I think the MH was recommended by several people. For some reason you seem to be unconvinced the product will work.
Question for you....... Why won't this product work for skim coating over an enamel based primer, to fill blemishes?
If you can use the product on exterior wood repairs under adverse weather conditions, you would think it would be ok inside a controlled environment?
Kevin
Kevin M. is offline   Reply With Quote
Old 12-19-2009, 02:03 PM   #3
Rewards Points: 188
Thanks for confirming the MH, I just completed the spackling.
Do I need to now spot prime these areas before using the Acrylic Satin Impervo?
Kevin, you are absolutely right.
I’ve made so many assumptions here and I’m concerned about compatibility of products/layers. FYI, I have a long hallway that was coated thick with many gross layers of paint slopped on over the decades, top layer was semi-gloss.
About four months ago, the guy in charge of repairs said, ‘Let’s skim coat this hallway and make it look like it’s not a tenement ghetto’. He ordered it to be skim coated.
I alerted the workers to the fact that they should probably either strip the paint, use a de-gloss liquid, sand, and perhaps use sheets of mesh also under the skim coat. They shock their head yes and then just skim coated directly over the semi gloss paint without so much as wiping it or cleaning it! I protested, but I do not own the place. They used joint compound mixed with some plaster. In under a handful of months, in several areas it's cracking, pulling away from the wall, de-laminating. Just this week, they came in and chopped off, re-skim coated with mesh, and sanded about 60 sq/ft. I just primed the repaired area this morning and was about to go out and buy expensive paint to do the top coat (btw, the floors in that area are being refinished early next week).
As I was priming, I notice that the skim coat was delaminating from the wall in even more areas! I'm completely demoralized and fed up. It means living here providing more access days to chump workers, more dust, more incompetence, moving furniture yet again, and yet more delays before resuming normal life. Gah.
That being the case, I wanted to DOUBLE CHECK to be absolutely certain the MH was the product for this purpose. I do not want more surprises.
Old 12-19-2009, 07:11 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
Yes,yes,and yes.
Old 12-19-2009, 08:14 PM   #5
Rewards Points: 188
Thanks Chris, I'll spot prime tonight along with the remaining priming. The Ben Moore Underbody Alkyd primer is an absolute pleasure to brush out compared to Coverstain (and I wonder how Zinsser managed to get it to reek so much, it couldn't have been easy).
I also got some TSP substitute and will use that for now on to clean prior to priming.
Old 12-19-2009, 08:48 PM   #6
firehawkmph's Avatar
Rewards Points: 1,800
Lgas,
When painting interiors, I paint all the wood trim, doors, windows, etc. to the finish. Make sure everything is dry for a day, then tape off woodwork and paint the walls. (blue tape)
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-20-2009, 05:57 AM   #7
chrisn's Avatar
Rewards Points: 136
Originally Posted by firehawkmph View Post
Lgas,
Mike Hawkins
Personally,I woud not put tape on fresly painted trim till it was cured,30 days.
Old 12-20-2009, 08:22 AM   #8
Too Short? Cut it Again!
My either.
And as far as patching dinged up trim? I would prime, use drywall compound, wet sand it, prime again, and paint a couple coats.
If you really want something more fine? Hit the art store. A little bucket of stuff like compound (Liquitex artist's modeling paste?) will set you back a few dollars but will go on smooth and will have finer ground marble or stone in it than compound does. You will need carbide sand paper to deal with it though.
Lookin for a small trim saw. Jim West Pa Tools 7 08-13-2009 07:12 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
Filling nail holes on paint grade trim? Yeti Carpentry 3 10-07-2007 10:53 PM
