Filling Holes In Wood Paneling Before Painting - Painting - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 11:09 PM   #1
lahomerpair's Avatar
Filling holes in wood paneling before painting
I am preparing to paint over paneling with lots of knots and holes in the wood. Should I use caulk, spackle or wood putty? I'm new to all of this, and have no idea. Perfection will be impossible, I imagine, because of the knots in wood. Also, the paneling is ribbed with 4 grooves per panel. This is only a problem when it reaches the ceiling molding and has a gap. I do not intend to fill grooves on the wall.
Thanks!
lahomerpair is offline   Reply With Quote
Old 07-23-2012, 06:42 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
We just had a discussion about paneling- here it is.
Use a taping compound if there are lots of them. probably need to hit them twice.
But prep and priming of the paneling is what is really important- read about it in the other thread.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-23-2012, 07:18 AM   #3
Gymschu's Avatar
Rewards Points: 830
I usually just use spackle. It's the easiest to work with. Wood filler becomes too hard and is not always easy to sand. Spackle takes primer and paint very well.
Old 07-24-2012, 03:01 PM   #4
Rewards Points: 45
This is a good question. I went the wood filler route since that was what seemed like the most logical option. Wouldn't drywall compound/spackle and the sort be a poor choice due to the differences in wood expanding and shrinking? Drywall's properties are very different and it wouldn't seem to jibe very well. Just a question from my side, not a condemnation.
Plump is offline   Reply With Quote
Old 07-24-2012, 03:07 PM   #5
I've ran into numerous homes in phoenix, and so cal areas that actually had sheetrock behind the wood paneling you speak of. Not saying this is the case with your home, but it very well could be a possibility.
CopperClad is offline   Reply With Quote
Old 07-24-2012, 03:52 PM   #6
Gymschu's Avatar
Rewards Points: 830
Plump, I don't have any science to back me up but paneling is an engineered wood product at least the paneling I have seen. It's usually NOT WOOD but some version of masonite that is actually more like compressed cardboard therefore you don't get the expansion/contraction like you do with real wood. I've used spackling for over 30 years without any problems.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (07-24-2012)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
painting over imitation wood paneling. kenjan75 Painting 2 09-14-2010 08:22 PM
Painting over weatherproofed wood Happy DIYer Painting 3 09-06-2009 03:27 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
