Filling Cracks Between Wall And Baseboard - Painting - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 09:22 AM   #1
Filling cracks between wall and baseboard
I have tried several times to fill the crack between the wall and baseboard in several places. It looks great for a while and then it shrinks and cracks. How can I permanently correct this problem.
rampart is offline   Reply With Quote
Old 07-03-2010, 09:59 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Make sure the baseboard is nailed good with very little movement. The best caulk in the world will still crack if there iss too much movement. Make sure you use a quality caulk. Dap is no longer quality in my opinion.
Old 07-05-2010, 03:13 PM   #3
Jim Dorff
Jim Dorff's Avatar
Filling the gap
Not only do you want to make sure the trim is secure to the wall, make sure you use a good flexible caulk that can expand and move with the wall.
Don't forget to make sure it is paintable caulking.
Jim Dorff
360 Painting of Ohio, LLC
www.360Paintingcincinnati.com
Jim Dorff is offline   Reply With Quote
Old 07-05-2010, 03:30 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Use caulk with a blend of acrylic and silicone, paintable, the acrylic will allow for some movement.
housepaintingny is offline   Reply With Quote
Painting baseboard tips/tricks mahjohn Interior Decorating 15 10-29-2011 11:54 AM
Help - Dilemma over water in the wall!!! SteveKnomull Plumbing 3 01-07-2010 10:59 AM
Installing baseboard trim on curved wall billyg Carpentry 8 02-06-2009 08:25 AM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 03:40 PM
baseboard around a bulge in wall henpest Carpentry 6 08-26-2008 05:57 AM
