Old 01-09-2013, 02:02 AM   #1
filler for cracked paint exterior window
need advice on filler for cracked paint exterior window, fix recommend easy filler to apply and quickly sand ready to paint. Cracked paint on window is solid so looking for quick filler/sand long last solution.
repairs is offline   Reply With Quote
Old 01-09-2013, 08:27 AM   #2
Filler More often you scrape off the loose paint, sand it to even it out and prime and paint two coats of finish paint.
Got picture so we can see just how bad it is.?
Old 01-09-2013, 09:37 AM   #3
Gymschu's Avatar
It depends........like Joe said, a pic sure helps. If you have removed as much paint as you can with a scraper/sander, etc. and you have hairline cracks, you may only need some caulking. If the cracks are bigger, some wood filler may be needed. If the cracks show signs of rot and are fairly large, you may need some epoxy. Just depends on what kind of cracks we're talking about.
Tags
cracked, exterior, filler, paint
Exterior paint for Pacific Northwest Andee77 Painting 8 08-28-2012 06:48 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
