Fiberglass Entry Door - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 06:09 PM   #1
retired guy
igneous's Avatar
Rewards Points: 137
fiberglass entry door
I have a black front entry door, presumably fiberglass. A wreath has scratched the door. I used a gray primer on these small areas, then used a latex paint, applied with abrush. After painting two coats, the primed areas are still raised. Can I sand these and start over? Would rolling the finished coat be better? Thanks.
igneous is offline   Reply With Quote
Old 05-30-2012, 06:13 PM   #2
you have to completely sand down the primer raised area til you can't feel it with your finger any more, and repaint another coat or two...
bbcmp1979 is offline   Reply With Quote
Old 05-30-2012, 07:03 PM   #3
Rewards Points: 14,306
Just so you know any door company I've even delt with has warnings about painting any door a dark color. If it's in the direct sun it will distroy the door over time.
Weatherstripping entry door to garage steppinthrax Windows and Doors 2 12-12-2011 11:28 AM
Widening patio entry 1/2 inch to replace door kozy Building & Construction 7 08-24-2011 11:04 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Old 80" wood entry door replacement janralix Carpentry 5 08-18-2009 12:02 PM
entry door repairs or replace? mudpaws Carpentry 8 06-08-2009 09:13 AM
