Old 07-10-2006, 01:05 PM   #1
Fence Stain/Sealant
I put up a new cedar fence last year and am investigating the best brand of stain(clear) or water sealant. I am currently looking at SuperDeck and Olymic Water seal. I am looking for any advice. I do plan on using a Wagner Paint Sprayer. Please Advise......
JenM is offline   Reply With Quote
Old 07-10-2006, 04:48 PM   #2
Painting Contractor
Fence Stain/Sealant
Use a High Quality product for your application.... DO NOT use what you stated you planned on using...
I recommend using Cabot's "Clear Solution"... if you want to keep the natural look of your cedar fence...
If you are using the Wagner Sprayer make sure you watch how you apply the material... you will need to go slow (so enough materials is applied)and make sure you over lap as you go... if you go to fast or dont over lap... it will not seal properly and/or look all blochy...
I recommend using a pump sprayer to apply the material...
JMGP is offline   Reply With Quote
Old 07-12-2006, 06:16 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Fence Stain/Sealant
Ditto
I'd recommend not using those products or applicator
I'd recommend Cabots also
And I'd recommend using a pump sprayer, or brush or pads, to apply it
slickshift is offline   Reply With Quote
Radio Fence Pet Fence Repair Wrangler08 General Discussion 3 01-01-2011 02:25 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
Fence Bid - A Rip-Off ??? kenziekiss Building & Construction 7 12-31-2006 08:12 PM
Constructing a New Fence With Neighbor Kwak Building & Construction 2 10-03-2006 02:41 AM
