Fence Stain - Acrylic Or Oil Based? - Painting - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 11:43 PM   #1
Question
Fence Stain - Acrylic or Oil Based?
Ok need help please. I have a fence in pretty bad color condition. Was thinking of using a solid stain.
Do you recommend an Acrylic or Oil based stain?
If not what type and brand of stain do you recommend?
I am looking to buy the stain tomorrow while some of these companies are having good Memorial Day sales.
Thanks to all who took the time to read and/or respond to my post.
OJ
ojtwelve is offline   Reply With Quote
Old 05-25-2009, 08:25 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Use Oil. Latex stain tends to peel. Sikkens is a great brand.
Old 05-25-2009, 05:57 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Oil/Alkyd-based does tend to stick longer and wear better (less prep for re-coat)
Acrylic, however, has less tendency to mold/mildew
It's a tough call
It depends on how often you are willing to do a maint. coat (should be before it actually needs it for minimal prep and best protection), and how much prep you are willing to do if you don't quite keep ahead of the game
I'd suggest Cabot's ProVT for acrylic
I'd suggest Sikkens Rubbol Siding for oil/alkyd
* IIRC the Sikkens is technically a hybrid
Regardless, it's certainly the best sticking, wearing, M/M resistant, oil/alkyd (hybrid) I've come across
-and I'm about 30 some odd miles out in the North Atlantic Ocean; constant salt air, big storms, hot/cold extremes, relentlessly-sunny/not-as-bad-as-inland snowy (but still pretty bad sometimes), frequent freezing rains, often droughts, 15 MPH winds considered a "calm day", whales in the back yard, migrating seals partying on your deck every spring/fall etc...
Basically a tough proving ground for any exterior product
(those seals get drunk easy and tend to spill quite a bit of ethanol...well...alcohol/booze... just about everywhere...it can be very hard on an exterior coating)
slickshift is offline   Reply With Quote
Old 05-26-2009, 09:38 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
A few things to note on Sikkens. Rubbol Solid Stain (the oil variety) is no longer on the market. It's been completely discontinued for Rubbol Siding Finish (the Acrylic version). You could use Rubbol DEK on it though. That is still an available oil based product though it will have a satin sheen instead of flat like the old Rubbol Solid Stain had.
poppameth is offline   Reply With Quote
Old 05-26-2009, 06:23 PM   #5
My Benjamin Moore dealer still caries the Sikkens Cetol Semi-Transparent Oil stain.
Old 05-26-2009, 07:53 PM   #6
100 Year Family Tradition
4ThGeneration's Avatar
Armstrong-Clark hands down. It has a greater window to work with in case you are slower and the sun tends to be your enemy when coating.
As far as the mold thing with oil. Oil is food for organic (living) mold. Its like putting a bird feeder out for a bird. One thing is that you should be cleaning your exterior home, decks, fences, concrete and other surfaces once a year anyhow, so do not sweat the mold. It comes off easy with the right chems and with a soft wash technique.
4ThGeneration is offline   Reply With Quote
Old 05-27-2009, 10:49 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
They haven't dropped oil in the S/T stains yet. Just in the solid siding type. They just came out with an acrylic solid deck product. The oil deck product may disappear soon as well if the new acrylic performs as well as the siding type does.
Second coat of oil based deck stain? cgoll Painting 4 05-04-2009 03:47 PM
Stain Shadow Box Fence rms_1938 Painting 1 04-18-2009 01:09 AM
Can oil based primer (zinsser) be covered with acrylic paint? tigerbalm2424 Painting 3 07-10-2008 09:48 PM
