Fence/ Gate Staining - Painting - DIY Chatroom Home Improvement Forum
Old 05-15-2014, 11:17 AM   #1
Rewards Points: 22
Question
fence/ gate staining
I had a new gate and fence installed last week and now I wanted to know if I need to have it stained and if so how long should I wait until I stain it?
Thanks,
Dave
dhd42 is offline   Reply With Quote
Old 05-16-2014, 09:05 AM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Yes, it should be stained to protect it from the elements, which would eventually damage the wood. It should be stained as soon as possible, once the wood is dry and meets manufacture specs regarding moisture content. Some facts about new wood http://www.kelloggspainting.com/blog...Wood-Care.aspx
housepaintingny is offline   Reply With Quote
Old 05-16-2014, 09:26 AM   #3
Rewards Points: 22
Thanks for the information and I guess I forgot one other point that may be important in what and when I need to care for the wood. The wood that was used was pressure treated so do I need to worry right away or should I wait any amount of time because it has been treated already?
Dave
Old 05-16-2014, 09:47 AM   #4
Rewards Points: 616
Dave
Yes, it should still have a stain applied to it when dry. I would probably wait about 4 weeks, however it may be dry already. We really would not know unless we use a moisture meter to see how much moisture content is in the wood.
Old 05-16-2014, 04:57 PM   #5
Painting Contractor
Rewards Points: 167
Some products are designed to go over new treated, and some not. After you narrow down what product you want to use, read the label and see what the manufacturer specifies. Personally, I would wait until Fall to give time for the salt to bleed out of the treated wood.
VAProPainter is offline   Reply With Quote
Old 05-16-2014, 06:44 PM   #6
Rewards Points: 14,000
There is no salt used in treated wood.
It's treated with copper.
Going to have to wait untill it's had time to dry out before treating.
No one knows where you live so no way to guess on how long you should wait.
Stain it to soon and the stain will not soak in to protect the wood and you'll be dealing with mold from then on because you sealed in the moisture.
Old 05-16-2014, 08:48 PM   #7
Painting Contractor
Rewards Points: 167
You're right, I was using the term "salt" generically. I still think some of the copper oxide can leach out of the treated lumber.
Old 05-17-2014, 01:15 AM   #8
Rewards Points: 22
so if i have a moisture meter what should the reading be on the wood before I stain or paint the wood? I'm near Washington DC so right now everything is really wet because we had a ton of rain the past few days.
And now I have to ask, how often should I re-stain the fence after it has been done?
Old 05-17-2014, 06:37 AM   #9
Jmayspaint's Avatar
Rewards Points: 534
The stain you pick should have guidelines on the maximum moisture content allowable when the stain is applied, generally its 18% or lower.
18% is a lot IMO, I like to stain when all the wood is at %14 or lower. Take several readings to make sure you don't have wet spots near the ground or in shaded areas.
How long in between maintenance coats will depend on several factors, but generally 2-4 years if you want to keep it looking good.
Jmayspaint is online now   Reply With Quote
turning a fence section into a gate echobravo Building & Construction 5 06-05-2012 01:29 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 05:43 AM
Advice needed on staining wood fence deerhunter Painting 0 10-29-2010 10:27 PM
Staining our fence? Shpigford Painting 2 07-23-2008 05:07 AM
