Faux Wood Paint Garage Doors - Painting - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 08:29 PM   #1
faux wood paint garage doors
does anyone know how best to faux paint garage doors?
alexandersh is offline   Reply With Quote
Old 05-21-2009, 08:53 PM   #2
The following steps depend on eventual stain color. First, apply a base coat ( lighter color for lighter stain. Then apply a gel stain. Finally, apply a clear coat to protect the gel stain. Good luck.
waynech is offline   Reply With Quote
Old 05-21-2009, 09:01 PM   #3
I had hoped to do one coat of gel stain and use the fake wood tool, then go back over with the same color gel stain so not so contrasting. Will this work? thanks
Old 05-22-2009, 01:06 AM   #4
Hi alexandersh,
I agree with your ideas. I am sure that it will work better. Please proceed with your decisions.
Regards
Austin Pieterson
austinpieterson is offline   Reply With Quote
Old 05-23-2009, 02:29 PM   #5
Art-Faux Designs Inc.
Rewards Points: 12
Graining ext doors
A couple of things I would like add here is when doing a graining on an exterior surface be sure that the product you are using is "colorfast" meaning that the proper pigments are in place for an exterior surface to prevent from fading
Most gel stains are for interior use and are not color fast because they sometimes contain dyes rather than pigments.
I live in Soutwest Florida and it is not recommended to use oil base products on exterior metal doors and will void the door warrenty so check the door manufacturers label on the backside of your overhead door before you procede.
The key to a successful job is to keep the door cool while applying your finish.
I have grained many a door in my 30 plus years of experience and what I do is stand a couple of extension ladders in front of the overhead door and clamp drop clothes to the front of the ladders with the strong spring clamps to create the shade that is needed, but be sure it isnt windy when you do this other wise you are creating a huge kite lol
ArthurM is offline   Reply With Quote
Old 03-01-2016, 12:50 PM   #6
Rewards Points: 4
question about mixing colors:
instead of using a stain, can you use exterior paint that has been thinned? If so, what is the best thinner? Mineral Spirits? Or, can you mix it with an exterior urethane?
drgerry is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Painting Old Wood Garage Doors DIYnewbie2 Painting 4 05-14-2009 06:11 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
