Old 01-22-2009, 09:53 AM   #1
Faux Painting
I have painted before (regular flat, satin finishes before) but the wife wants faux paintng done. Need help. What are the steps involved? i have builder white walls right now. I have couple rooms to do. Or would it be more cost effecient to hire someone? How is it priced out? per room or per sq/ft?
shouldItryornot is offline   Reply With Quote
Old 01-22-2009, 03:43 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Faux Painting
Rule #1: Use a latex glaze over a latex base coat, or oil glaze over an oil base coat
Rule #2: There are no other rules
Well...make sure your base coat is at least an "eggshell" sheen, flats absorb to much glaze
Other than that/those, it's really a matter of preference and your idea of fun
Today's latex glazes are great, no need to use oils as in the past
I'd practice first...it's unlikely you will get the desired effect first try
Benjamin Moore's website has some info on faux, the difference between additive and subtractive, and various techniques
But like anything else on the subject, it's by no means comprehensive
But it'll get you an intro to the genre
Bonus Tip: Newbs will probably want to add the extender, increasing the "working time" of most glazes, as they sometimes dry quicker than we suspect at first
Bonus Tip #2: Your base coat is your eraser
If you don't like what you've done, re-coat with your base coat and start over
Obviously, this goes better with the practice part, as re-coating a whole room can be over-whelming
But it does help to know if you like what worked on three walls, but the fourth is "iffy"
slickshift is offline   Reply With Quote
Old 01-23-2009, 01:16 AM   #3
Faux Painting
Thanks for the tips ill check out the bm site by teh way do you know how a pro would price stuff like this out?sq/ft? or by the hour?
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Faux painting techniques bighorn27 Painting 1 11-06-2005 04:08 PM
