Faux Finishes On Already Textured Walls - Painting - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 10:52 PM   #1
faux finishes on already textured walls
Our walls are very textured, but I really like the the linen style technique that I saw at Lowe's. Would this idea work with the type of walls I have? It would be used for our small powder room. I don't want to try things like this on a really big space...yet!
Our Walls
Linen Technique and color that I like
What do ya think?
aimless07 is offline   Reply With Quote
Old 11-04-2008, 06:25 AM   #2
Great to have pictures...............
Your linen technique will still have the texture you already have. If you take notice to what you have already posted, the linen appears to have a flat surface. Your walls have a knock down texture. If your wanting to do a bit of work you can skim coat your walls to make them a flat surface. Then you may go ahead and do your linen technique finish. Good Luck.............
mark942 is offline   Reply With Quote
Old 11-04-2008, 07:03 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
A strie or linen faux, or even linen texture will have a tough time over what's on there now
You'll want to skim coat the area with a thin layer of joint compound to make them smooth first
slickshift is offline   Reply With Quote
Old 11-04-2008, 09:28 PM   #4
Drywall contractor
Rewards Points: 1,070
Or perhaps two coats of compound (and sand) to make them smooth. Joint compound shrinks as it dries and a texture usually requires more than one coat to cover.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-04-2008, 10:26 PM   #5
thanks for the suggestions. i may have to ditch the linen technique b/c i don't know how to do skim coats! would another faux technique work with my type of texture?
Old 11-04-2008, 11:05 PM   #6
Drywall contractor
Not that familiar with the faux finishes, but I'm pretty sure you need a "reasonably" smooth surface to begin with. I do know from experience that drywall textures (as a rule) require scraping and a couple of coats of mud to get to a reasonably smooth surface to begin another finish. You might want to try the "painting" forum for further (and perhaps better) advice in regards to the specific finish you're looking at........those guys should know.
painting over textured walls letigre Painting 3 07-29-2008 05:12 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
Textured walls Dafeesh Painting 5 03-04-2008 10:58 PM
Help with new cracks in textured walls Giants2112 Building & Construction 3 01-25-2008 08:23 PM
using faux stone on interior walls...? DIY4EVER Building & Construction 21 12-21-2007 10:43 AM
