Fat (2" Circumference) 4" Rollers Vs. Regular Hot Dog - Painting - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 12:55 PM   #1
Rewards Points: 1,062
Question
fat (2" circumference) 4" rollers vs. regular hot dog
I was wondering if anyone could explain what the difference in application is between the regular skinny hot dog 4" rollers vs those that are much bigger in circumference (like 2"). also, what is the name for the latter.
Here is what I am referring to:
http://www.amazon.com/Wooster-Brush-...=cm_cr_pr_pb_t
Old 04-21-2013, 01:46 PM   #2
Rewards Points: 13,450
More surface area to hold more paint.
amakarevic (04-21-2013)
Old 04-21-2013, 01:55 PM   #3
Question
do you know if the fat ones cause more splatter for that same reason?
also, do you know what the fat ones are called?
Old 04-21-2013, 03:59 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
I like the little hot dog shaped ones that are about 1" in dia.....the get into tight areas well....like behind the toilet tank.
Splatter? The all splatter....some just more than others....and depends on how fast you go....
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 04-21-2013, 06:27 PM   #5
"Hot dog" rollers are for what dawg pointed out, for getting behind tight spaces and rolling things like spindles, pipes, etc. They're really not for rolling walls. I've used the 4" velour/mohair minis for finish rolling shelving and cabinets and it leaves a nice factory looking finish. The 4" (2in dia) are just the short end of the standard roller cover length - 4, 7, 9,14, 18" - and they come in 1/4, 3/8, and 1/2" naps. They are designed for rolling walls and come in handy when you have a lot of areas too small for a 9" (or 7) cover and too large to brush out, or where a nap texture is preferred/required over a brushed look. There are multiple other uses for each, but technically, they're not exactly interchangeable.
Tags
paint rollers
How to patch around a 2" x 4" hole in back of furnace darlingm HVAC 16 08-22-2011 06:22 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
do they make a PVC 4" "T" with a 2" off the side? What have I done Plumbing 5 08-24-2009 04:37 PM
