Old 07-03-2012, 06:21 PM   #1
Smile
Famowood Glaze Coat not curing and remains sticky
If you have a problem with your Famowood Glaze Coat remaining sticky after applying and curing for 48 hrs, pour peroxide over the entire surface and let dry for 30 minutes. I used this product on mosaic trivets that I made and had to pour more than the recommended thickness of 1/16". When it remained sticky, I called the company and they recommended using a lint free cloth and acetone then pouring a very thin coat on top of the sticky surface. This did not work. I tried the peroxide and it worked great!!! And alot less expensive!!
MsGeorge is offline   Reply With Quote
Old 07-03-2012, 06:35 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
I have no idea what your talking about.
Is this paint related?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
