Extra Lights When Painting - Painting - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 10:53 AM   #1
As I am getting older, as we all are, I have found that my home has one light in the middle of the room and I end up 'touching up' all around the room as I missed it. I am blaming the lighting! I purchased a small 500W halogen light but it's blaring too much.
Guess my question is what do pro's do for lighting in dark rooms when painting them?
Thanks!
pinkfloyd43 is offline   Reply With Quote
Old 11-28-2012, 11:31 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Lighting is very important- particularly in winter.
I have used a variety of lights, including the halogen. I also found it to be a poor light to paint with.
I invented a light box using 4 100w equivalent florescent that I use all the time. A couple of these will light up a room and are not dangerous for the heat like a halogen.
Here's the idea-
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-28-2012, 02:02 PM   #3
Here's the idea-
I am thinking you built that? If you did purchase it let me know where?
Thanks!
Old 11-28-2012, 02:30 PM   #4
Yes- homemade. You can buy florescent work lights, but this just uses the regular bulbs so they are cheap and easy to replace.
Plastic box, a bit of hardware etc.
If you are handy , look at it and recreate.
Old 11-28-2012, 02:35 PM   #5
Too Short? Cut it Again!
Just don't judge color by any but the more expensive full spectrum flourescent. Most have absolutely dreadful color rendering indexes. Most halogens, on the other hand, have decent CRIs.
When I needed light, I had the typical cheap halogen worklights but I swapped the bulbs out for some less bright than the 500w ones that come with them. You could also try a theater gel over the lens of the thing (assuming yours has a piece of glass) to diffuse the light some.
You might try aiming the light off the ceiling to see if that provides you with enough?
A friend, a painter, somehow ended up with lots of lights from a photographers studio. They were great and came with diffusers and baffles.
Old 11-28-2012, 03:58 PM   #6
Gymschu's Avatar
Rewards Points: 476
I actually like the halogens. Yes they are really bright and really hot, but, if you angle them just right, they throw a perfect light on the wall. I also have used the very inexpensive aluminum clamp lights. You can put almost any watt bulb in them to shed just the right amount of light.........if you lose it or break it, well, they only cost about 8 bucks. The clamp makes it nice to attach to a ladder or just about anything else to bring the light closer to your work area.
Gymschu is online now   Reply With Quote
Old 11-28-2012, 08:07 PM   #7
ltd
Rewards Points: 536
yea i use halogens ,i always have to be careful dogs and cats like to stare at them .
ltd is offline   Reply With Quote
Old 11-28-2012, 09:30 PM   #8
You also have to be staring to realize someone else is staring.
Staring at halogen lighting can cause spelling and punctation irregularity disorder.
The only real light to paint in is daylight. I've cut in dark halogen lit rooms only to come back in the daylight to question who the hell did that.
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (11-29-2012)
Old 11-29-2012, 09:56 AM   #9
Rewards Points: 81
I've got an old brass floor lamp my father used, and possibly my grandfather. It has three regular bulbs around a three way bulb in the center. I'm actually thinking it could be a nice lamp if I could clean all the paint off.
Just discovered its called a mogul lamp.
tev9999 is offline   Reply With Quote
The Following User Says Thank You to tev9999 For This Useful Post:
3-way with extra lights on circuit dvaupel Electrical 21 07-13-2012 04:25 PM
Lights still dimming and flickerin Keisha34 Electrical 18 06-09-2012 12:14 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 07:28 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
