#1 |
Exterior Wood
I am getting ready to paint exterior wood that has not been treated. Is primer necessary and what would be the best choice. Can i get water based primer?
#2 |
Painting Contractor
Exterior Wood
You must prime...Use a Premium Primer... You can use a latex primer...
Benjamin Moore's Fresh Start Primer is good.... |
#3 |
Pro Painter
Exterior Wood
What type of wood is it? Meaning, is it pressure treated or not? If it's brand new pressure treated, your best bet is to let it wheather for at least 30 days so that the chemicals used to treat it can dry out completely. If it's not pressure treated you can prime and paint right away, assuming the surface is clean. It's not a bad idea to lightly sand new wood with 150grit paper to help open the pores and remove any mill glaze from the wood.
I would recommend a quality oil base primer followed by either latex or oil topcoat. If you want a decent water based primer try Zinsser's 1-2-3. Also, one last note. If it's not wood that is not attached allready, priming all sides of the wood, and the end grain (including any cuts that need made) will make both the wood and the paint last much longer...... |
#4 |
Tired, Cold, and Damp
Exterior Wood
To better answer your question, it would help if you posted up what is being painted
A deck, shed, siding, front stairs, birdhouse, etc. Whether it is pressure treated ot not And what type of use it would be getting Heavy use, not much... That would make it easier to recommend the best course of action In general, yes you need to prime And yes, you can get a water-based primer |
#5 | |
Painting Contractor
Exterior WoodQuote:
You are always thinking slick... I didnt even think to ask questions... |
| Display Modes | |
