Exterior Use For Kilz Original - Painting - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 10:58 AM   #1
exterior use for kilz original
can you use kilz original primer on exterior wood
serge2000 is offline   Reply With Quote
Old 08-26-2012, 11:00 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
There are far better.
To start with, get a zinsser product.
And have it say exterior.
What are you priming, raw wood, painted wood? siding?
Just noticed you said original- which is their oil. I think it is just an interior product. But it would say.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-26-2012, 11:03 AM   #3
Rewards Points: 13,300
Kilz to me is like using milk to try and prime. I've had 0 luck with it covering or sealing even the slightest stains or feathered out old paint.
Old 08-26-2012, 11:29 AM   #4
... joe- this is the oil...
Old 08-26-2012, 11:55 AM   #5
Gymschu's Avatar
Rewards Points: 490
I know KILZ gets bashed on here a lot, but it does have its' uses. I think it is fine as a minor stain blocking agent.......i.e. water stains on ceilings.......but not so good at hiding pine knots or even crayon marks on walls. I have used it with GREAT success as a primer on cabinets that have poly on them and are going to be painted. It's "stickability" is very good. And, for the record, I am talking about the oil-based KILZ.......never had any luck with the water based version. And, to answer the OP's question, NO, I would not use it for exterior use.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
chrisn (08-26-2012), user1007 (08-26-2012)
Old 08-26-2012, 12:42 PM   #6
Too Short? Cut it Again!
I am among the first to send up a red flag when I hear KILZ is being used but the first thing that comes to mind is the waterbased product which is worthless. The oil is alright and the rattle cans can even come in handy in a pinch.
There are better products out there like just about anything in the Zinsser line, Ben Moore Fresh Start---oil or waterbased---etc. And of course I think self-etching metal primers a good idea for gutters, metal window frames, metal roof vents and flashing and such things but certainly used high bond ones also.
Old 08-26-2012, 12:54 PM   #7
Where to Use
KILZ® ORIGINAL blocks most stains including water, smoke, tannin, ink, pencil, felt marker and grease, and seals pet and smoke odors. Use on interior surfaces including wood, drywall, plaster, paneling, wallpaper, masonry, brick, painted metal and properly prepared glossy surfaces. KILZ ORIGINAL is not recommended on flooring.
Old 08-26-2012, 05:48 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
CAN you? by all means but it is not labled for exterior use, read the can
Old 08-27-2012, 12:20 PM   #9
Rewards Points: 394
People still ask for permission, even if the label instructions say otherwise....
Will22 is offline   Reply With Quote
Old 08-27-2012, 04:54 PM   #10
chrisn's Avatar
Rewards Points: 234
Well, I gave him(her) permission
Best Knockoff of the Original handy man88 Tools 2 02-06-2009 04:27 AM
Noise Reduction of Original HardWood Floors artist082483 Flooring 2 10-09-2008 05:57 PM
Rewiring Original 1952 house. TripleC Electrical 2 03-11-2008 11:11 AM
Most original bathroom design idea I have ever seen athena79 Interior Decorating 4 10-04-2007 12:04 PM
second floor addition without removing original roof coralhead1 Building & Construction 8 10-06-2006 06:56 AM
