Exterior Trim Painting - Painting - DIY Chatroom Home Improvement Forum
Old 09-06-2007, 08:40 PM   #1
Rewards Points: 150
exterior trim painting
Hello
I have successfully Removed all the flaky paint and removed all the paint with a heat gun on the window sills. everything looks great I primed with zingers 123 tint primer. on the bear wood.today.
Now I have a few more questions!
The paint that is on the window trim that is still good a ( flat paint !), Should I prime over all the existing old paint, or just paint the top coat over the existing flat paint?
Or prime over everything again 100 % then do the top coat ?
top coat will be same color, Gliddens Endurance semigloss .
should I give it two coats of top coat?
Deck Hand
deck hand is offline   Reply With Quote
Old 09-07-2007, 10:20 PM   #2
Workaholic's Avatar
Usualy after you have done all your scraping and sanding you will only need to prime the bare spots.
yes i would apply 2 coats of top coat, it will give you much better results.
Sean
Workaholic is offline   Reply With Quote
Old 09-08-2007, 08:59 AM   #3
Rewards Points: 150
Deck Hand Sat Morn
Old 09-19-2007, 07:33 AM   #4
Rewards Points: 150
Smile
Exterior trim painting Thanks!!
Thanks to those who replied to my request on painting exterior window trimmings of my daughters home, Sean and Workaholic.Thanks.
She was quoted $ 3,500.00 plus carpentry work on the job I was able to do it labor free the material's came to about $ 280.00 plus my gas driving back and forth. I used Z's 1-2-3 plus tint as a primer and Glidden's best exterior Endurance two coats This paint was one of the best I have ever worked with.
I highly recommend it, One coat covered perfect. but a second coat was recommended , so I did two coats. Buy the way if anyone is interested
I used a heat gun on the window sills then sanded windows.
Deck Hand
Old 09-19-2007, 04:12 PM   #5
Workaholic's Avatar
Great i am glad that it all worked out, and that you were able to help your family out. Thanks for keeping us posted.
Sean
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 08:00 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
Hairline Cracks after painting parasailing Painting 8 07-24-2006 12:47 AM
Painting an asphalt driveway surfitness Painting 4 08-25-2005 12:08 AM
