Old 10-14-2011, 07:28 PM   #1
Exterior spackle
Did a Google search on exterior spackle, very confuseing.
I replaced some soffit 3/8 plywood. The soffit is flat, horizonal out of the weather.
Lots of holes from stapler and a couple small uneven spots where boards meet.
Can I use joint compound? I've got lot's of joint compound and soft sand.
JIm
jjrbus is offline   Reply With Quote
Old 10-14-2011, 08:11 PM   #2
ltd
Exterior spackle
. the reason you cant is because it is for interior.in other words i don't know.probably has to do with moisture . but what i do know is i like to use ready patch its like a spackle on steroids it can be used exterior.home creepo sells it and some pro paint stores sell it. one small can about 5 bucks should do it.
ltd is offline   Reply With Quote
Old 10-15-2011, 04:18 AM   #3
paper hanger and painter
chrisn's Avatar
Exterior spackle
Use this, works great,
joint compound?
chrisn is online now   Reply With Quote
Old 10-17-2011, 08:19 AM   #4
Exterior spackle
Thanks guys
I bought the DAP because that is what they had. Such a waste, I used about 1/2 cup. IS there a for sale section here?
Old 10-17-2011, 05:02 PM   #5
Exterior spackle
I like this stuff. you only mix what you need, and the rest will last forever (as far as I can tell...)
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 10-17-2011, 05:20 PM   #6
chrisn's Avatar
Exterior spackle
Work fine, IF , it does not get wet.
The Following User Says Thank You to chrisn For This Useful Post:
ltd (10-17-2011)
Old 10-17-2011, 05:54 PM   #7
Gymschu's Avatar
Exterior spackle
Most spackles are made for interior OR exterior use.
Old 10-19-2011, 12:04 AM   #8
Exterior spackle
Originally Posted by Gymschu View Post
Most spackles claim that they are made for interior and exterior use. In fact they are mostly designed for interior.
Fixed.
StevenH is offline   Reply With Quote
