Exterior Spackle.... - Painting - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 01:23 PM   #1
Rewards Points: 492
exterior spackle....
think I'll probably just have to buy another piece of AZEK, trying to avoid wasting a piece. It's expensive!
here's a direct link, may be able to take a closer look.
after a long day working, apparently too long, I cut a piece a bit short. I cut two 45s and attached another piece, not liking the connection I was getting when I just used bevel cuts and over lapped the pieces.
I scuffed/bruised up the piece real good when I was sanding (yeah I used a belt sander). I've got the two pieces flush, and I was wondering if there is an exterior spackle I can use on AZEK. I know I will have to paint it now that I am using spackle, but I've had to do some caulk work as well so it needs to some paint for a semaless look.
as always, thanks!
joetab24 is offline   Reply With Quote
Old 08-12-2011, 05:45 PM   #2
You've just spent more in time and material than you would have if you just bought a new piece, and to boot, it'll never look right. Buy a new piece, cut your losses.
Old 08-12-2011, 10:18 PM   #3
Rewards Points: 492
I hear ya J, and I still may do that. I did manage to clean this piece up pretty good. I will be painting the AZEK. I want to look at it then. Any experience painting AZEK? thanks for the reply
Old 08-13-2011, 12:02 AM   #4
Never really had any experience with it. From what I understand, it's early yet, as most who put it up do so to not have to paint, among other reasons. I've asked about it and from what I've been told, you paint it just like any other material. Time will tell.
Old 08-13-2011, 01:59 PM   #5
I dont care what brand of exterior Spackle, what they claim. None of them will last long. At 45 degrees it will expand and contrast, ending up with hair line cracks. The only stuff will last long is caulk. Big Stretch is one of my favorite.
StevenH is offline   Reply With Quote
Old 08-13-2011, 06:12 PM   #6
The only patching compound I've had good results with exterior is Bondo. It's a pia, but it's the only one I've had that doesn't crack and fail. They now make a bondo for home repair.
Old 08-13-2011, 06:37 PM   #7
kwikfishron's Avatar
Rewards Points: 208
Iíve had good luck with this stuff and it will bond to plastic. Iím just not sure about sanding AXEK.
http://www.wholesalemarine.com/p/F-E...FYjsKgodZQoh0Q
kwikfishron is online now   Reply With Quote
Old 08-13-2011, 06:56 PM   #8
I have used Pc Woody Epoxy Paste
http://www.amazon.com/Woody-Epoxy-WO.../dp/B000H5O7Y8
Good stuff
Have you used Minwax wood filler?
http://www.minwax.com/wood-products/...ce-wood-filler
The Following User Says Thank You to StevenH For This Useful Post:
jsheridan (08-13-2011)
Old 08-13-2011, 07:17 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
if you glued the 45 with pvc glue it will never separate,a 2 part epoxy will work, bond and fill makes one but it's not cheep
Tom Struble is offline   Reply With Quote
