Exterior: Scrape? Sand? Waterblast? - Painting - DIY Chatroom Home Improvement Forum
Old 03-13-2005, 01:44 PM   #1
Exterior: scrape? sand? waterblast?
Exterior is overdue for paint. [long boring story] and painter quotes vary enormously, depending on the labor for surface preparation. A lot of old chipping and decades old paint edges need to be removed. I experimented with a hand scraper, and decided that my grandchildren would have to finish the project. Next attempt was a palm sander, with not much success. Next effort will be a belt sander with 80-120 grit. Any suggestions?
robertpri is offline   Reply With Quote
Old 03-13-2005, 01:50 PM   #2
Paperhanger/painter
ProWallGuy's Avatar
The level of prep required is determined how you want the finished product to look.
You want a brand-new fresh siding look, or just want a good paint job that will perform as long as possible?
ProWallGuy
Professional Wallpaper & Paint Co.
ProWallGuy is offline   Reply With Quote
Old 03-13-2005, 02:03 PM   #3
Yes, the range of quotes are gigantic! Of course, I want a Mercedes finish, but that's not reasonable. I would run out of money before the painting even starts!
I have reduced my "vision" and will prep the front face as best as possible, which probably means detailed sanding. On the sides and back, then duration and performance will be the goal.
Old 03-13-2005, 02:21 PM   #4
Contractor
Before you get too far along, you might want to have the old paint checked for lead. This may have a bearing on removal techniques.
Teetorbilt is offline   Reply With Quote
Old 03-13-2005, 03:10 PM   #5
Thanks. No, bought it myself years back. Ordinary water-based latex
Old 03-13-2005, 08:34 PM   #6
Contractor
You might want to take a look at these. Paintshaver will try to sell you their cutter inserts but you can buy them for about 1/3 the price from someone who sells to machine shops. They use them here for removing bottom paint and gelcoat. The cost might shake you at first, but think of the time saved and all of the belts that you will buy. Stick it on ebay when you're finished with it.
http://www.silentpaintremover.com/
http://www.paintshaver.com/
Old 03-13-2005, 10:41 PM   #7
Very impressive! I'd like to see one in action. Yes, a bit pricey--maybe I'll check ebay for used.
After the last post, I tried a belt sander with 80 grit. Worked, ah, semi-okay, but was told to get 35-50 grit for the next attempt. Final results were pretty good actually, but looking at the size of the house, and how long it took for 100 sq feet--wow!
Old 03-14-2005, 06:34 AM   #8
Paperhanger/painter
ProWallGuy's Avatar
Go to the paintshaver page, and click on 'view video'. Looks awesome to me.
ProWallGuy
Old 03-14-2005, 12:39 PM   #9
The paintshaver looks awesome, but wouldn't a planer do a similar albeit slower job, at a much cheaper price. Or how about a sanding disk or wire disk for an angle grinder.
LAB RAT is offline   Reply With Quote
Old 03-14-2005, 06:06 PM   #10
Paperhanger/painter
ProWallGuy's Avatar
A planer would most likely work. I have used the sanding disc and wire wheel, and didn't like how it tended to leave half-moon shaped indents in the wood.
ProWallGuy
Old 03-21-2005, 10:53 PM   #11
Painting Contractor
Humble Abode's Avatar
Now you know why those quotes were so high?
Humble Abode is offline   Reply With Quote
Old 03-22-2005, 09:08 AM   #12
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
I use a power washer for the first pass on exterior paint jobs, first house I did it on was mine, it knocks pretty much all the loose stuff off, but you still have some hand scraping to do afterwards. Also removes dirt and mold pretty well too.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 03-22-2005, 10:34 AM   #13
Long-Time DIYer
Mike Swearingen's Avatar
Many of the pros around here use a heatgun to remove all of the old scaled paint down to the bare wood, then fill any dents and dings, prime and paint. Looks like new to me.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-22-2005, 01:30 PM   #14
Paperhanger/painter
ProWallGuy's Avatar
Mike, that is hands down the best way to go. Only thing is its hard to sell these jobs due to price. Too many so-called paint contractors won't do it and bid in low, and are awarded the job because the customer doesn't understand the different levels of quality.
ProWallGuy
Old 03-22-2005, 05:11 PM   #15
aka:awesomedell
Rewards Points: 150
I've got a heat gun that I use for removing glue on interior walls, say like if paneling is removed, never had considered using it for removing exterior paint. I can see how it would work well, but yeah the price you'd have to charge would lead to loosing out on alot of bids.
So am I doing things the wrong way Prowall? As I stated I hit it with the power washer, then we scrape, scrape, then primer & fresh paint. Not that I bid alot of exterior painting, everybody & their brother is a painter in this area. Mostly I bid on new vinyl siding or fibercement if they really want the best.
