Exterior Professional? - Painting - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 07:09 AM   #1
Can you spray stain on Cedar Siding
Alcarte is offline   Reply With Quote
Old 02-01-2011, 07:23 AM   #2
DIY staff
Rewards Points: 7,174
Yes you can--use an airless sprayer (paint pump)--
Be careful of cars--sidewalks--any thing close----stain will drift in the air for quit a distance--
Pick a windless day.
I dusted my helpers truck once--it was parked at the curb----Mike---
Old 02-01-2011, 10:37 AM   #3
Rewards Points: 394
You can also use a low pressure sprayer (Hudson-type garden sprayer). It is less prone to overspray than an airless. It will also provide better transfer efficiency. Once the spray is applied, you can brush or roll to even it out.
Will22 is offline   Reply With Quote
Old 02-01-2011, 03:50 PM   #4
It can be done. Me personally, if I was gonna spray stain I would use an HVLP or a Cup Gun. Airless is dangerous with over spray. I wouldn't use a garden sprayer as commented above that is a disaster waiting to happen.
Shipp's Painting LLC
http://www.paintingkokomoindiana.com
Shipps Painting is offline   Reply With Quote
Old 02-01-2011, 03:51 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
What kind of stain? Oil? Waterbase? Solid? Semi-solid? Translucent? Semi-translucent? What brand? Depending on the answer to these questions it may or may not be efficent to spray the stain.
housepaintingny is offline   Reply With Quote
Old 02-01-2011, 04:50 PM   #6
I'm considering a solid stain the house gets a lot of direct sunlight and the previous owner had a semi-transparent stain put on it less than 3yrs ago and I looks terrible, my brand of choice will be sherwin Williams
Old 02-01-2011, 04:56 PM   #7
Rewards Points: 616
You will have no problem spraying SW solid woods capes stain with an airless sprayer. I would suggest you use a 415 tip. It will give you an 8 inch wide fan and a little bit better control with less over spray than a tip with a larger orifice.
Old 02-01-2011, 05:07 PM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I would still backbrush.............
tcleve4911 is offline   Reply With Quote
Old 02-01-2011, 05:39 PM   #9
Rewards Points: 616
I would back brush the first coat and just spray the second. You could even use a roller and back roll it sideways instead of up and dowm
Old 02-02-2011, 01:51 AM   #10
Super Master Painter
Ole34's Avatar
you would be better off brushing it ..............take longer for you but less problems .........simple work, get a brush and ladder and some stain and some elbow greese..........have a beer when your done or glass of wine if your a female
Ole34 is offline   Reply With Quote
Old 02-02-2011, 03:33 AM   #11
Ole34's Avatar
ONE MORE THING..........dont try an fill the bee holes, they will just makes new ones right next to the ones you filled
Old 02-02-2011, 06:01 PM   #12
Professional Painter
I would recommend spraying it, and then brushing it to fill it in.
mattroefer is offline   Reply With Quote
