Exterior Painting, When Cold - Painting - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 11:16 AM   #1
Rewards Points: 222
exterior painting, when cold
when is it too cold to paint outside ?
Fix'n it is offline   Reply With Quote
Old 10-03-2012, 11:41 AM   #2
Gymschu's Avatar
Rewards Points: 488
When the surface temperature of what you are painting is 35 degrees or lower. Personally, to play it safe I rarely paint outside in temps lower than 50. Why? Because night time temps can dip below freezing and cause all sorts of problems for new paint film. You really want your paint to CURE and for that to happen you really don't want temps dipping below 35 for at least a couple weeks. This time of year is tricky because it can be 70 during the day and then get foggy/dew at night as temps drop drastically overnight. I always plan on somehow making sure the sun hits the side I am working on for at least a couple hours to give the paint a good chance of drying before evening.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
user1007 (10-03-2012)
Old 10-03-2012, 05:54 PM   #3
Too Short? Cut it Again!
I did not do a lot of exterior work but when I needed two pairs of mittens and the paint in the can was frozen solid, I guessed it was getting too cold to work out well.
Seriously and as mentioned, when temps cannot be counted on to be above 50 and especially if you live in a climate with a dew or fog issues that settles below 40 it would be best to wait until spring.
That said, there are exterior paints and stains, and additives that say they extend outdoor work to 40 or below. I guess I am too skeptical to buy into the concept.
Old 10-03-2012, 06:46 PM   #4
Gymschu's Avatar
Rewards Points: 488
A good rule to follow is an ancient painter's rule.........if it HAS to be done then by all means paint it even tho it's cold out, if it can wait til spring, well, wait til spring!
Old 10-03-2012, 08:57 PM   #5
Rewards Points: 222
thanx guys. thats about what i was thinking.
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
Adding on to cold air return agicr HVAC 13 03-27-2011 02:33 PM
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 06:50 PM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
